What you need to know before buying a starting and charging device?
In the life of each owner, there comes a time when it is necessary to use a starting-charger to start the car. The design is especially necessary in winter time, because at subzero temperature the battery discharges much faster. The versatility of modern models also allows you to quickly charge the battery, preventing its full discharge. So, using the device, you can ensure a quick and easy start of the engine under any circumstances.
Start-Charger Classification
Due to the fact that now ROMs are presented in a wide range, conditionally they are divided into the following types:
- Household-designed for use in the garage or on the road. In most cases, they can work with an output voltage of 6-12 V. It can be used not only for cars, but also for suitable motorcycles. Some models are additionally equipped with overheating protection, a voltage stabilization system and other functionality.
- Professional-in terms of functionality, they practically have no difference from home appliances. Their feature is only in higher power, as well as the ability to charge multiple batteries. Can be used for cars with a voltage of 12, 24 and even 36 V.
The type of charger depends on the purpose for which you will use it and in what conditions.
For example, if you have a garage with a network, a stationary device would be a practical option. In addition, modern models are available in compact sizes, so the design will fit even in the smallest garage.
If you leave your car in the yard or in the parking lot, it is recommended to choose an autonomous model that can work without a network.
Important Technical Indicators
The model should be chosen based on the key characteristics of each model specifically battery charger :
- Output voltage is the most important parameter. Its value must match the number on the battery. If this is not foreseen, two scenarios are waiting for you: either the device itself or the battery will burn. If the latter provides two values, for example, 12 and 24, then you can safely choose a ROM from both 12 V and 24.
- Charging current: the parameter value can vary from 20 to 3 thousand. A. The choice of a particular number depends on your car. For example, 55 A is enough for a passenger car, but 1000A and more for a cargo car. Please note that the charger provides the minimum charging current at which work can occur and the maximum value.
- Voltage is the value of the parameter to which the charger can be connected. Most often it is 220V., But there are models providing 110V.
It is recommended that you choose a device with a variety of protective features that increase safety of use and additional features that improve operating comfort. For example, you can confuse in a hurry terminals, and this will lead to problems in the onboard network. The presence of a special function will allow you to avoid such breakdowns.
Some drivers have a question: why buy a starting-charger in the presence of a generator. But it works only up to a certain point, for example, if the load on the onboard network grows, then the generator power will not be enough, this is where the battery helps.
You can buy a charger in Kharkov, Odessa, Kiev with delivery in Ukraine at 130.com.ua, where a wide range of products is provided: everyone will be able to choose a model according to their preferences and free budget.
Materials on the topic
Starter-chargers: Best Sellers
