What is dangerous about underfilling or oil overflow in the engine?
Oil is responsible for the normal operation of all elements of the engine, as well as their seamless interaction by friction. The car owner should always control the level of the fluid and avoid overflowing or underfilling.
First you need to understand that reading the probe needs to be correct. To do this, use the following guidelines:
Checking should be carried out on a cold engine, or wait half an hour after the trip. This is necessary in order for the oil glass to be in the crankcase, otherwise you will get an incorrect value.
The car should be on a flat surface.
We check in two steps: we take out the dipstick, wipe and re-insert it-we get accurate information about the oil level.
Most often, the stylus pen is painted yellow or red, and is also in an easily accessible place-everyone can find it, even someone who doesn’t understand cars at all.
This element has a minimum and maximum mark. Ideal when the oil column is in the middle.
Low engine oil level
If the oil level does not reach the minimum mark, it is not recommended to operate the machine. Otherwise, the consequences will be the most deplorable: one cannot do without expensive repairs. In fact, in such situations, small parts rub against each other without oil, which significantly reduces their lifespan.
Insufficient level of oil in the engine will lead to such troubles: stuck pistons, inverted liners, etc. To fix this problem is very simple-fill in oil and can enjoy further trips.
High oil level
It is a mistake to assume that exceeding the maximum mark is only better for the engine due to the reduced friction force. In practice, we get a completely different picture: lubricants foam, the liquid itself burns faster, rubber seals collapse.
Overflow of oil in the future can lead to the following consequences:
- The occurrence of carbon on the pistons, the walls of the cylinder.
- The exhaust system disrupts its performance by releasing a very large amount of oil through the system’s main line.
- Increased fuel and oil consumption.
- Spark plugs do not work as well.
To fix this problem, you just need to remove the excess oil. This can be done with a hose or through a cork in the pan.
It is recommended that you check the oil level at least once every few weeks in order to detect a shortage or excess in time. Also pay attention to the designs themselves with liquids to avoid unpleasant situations on the road. you can buy motor oil with delivery in Ukraine to Kharkov, Kiev, Odessa at 130.com.ua.
Related Materials
