Car vacuum cleaner: features of choice, design, characteristics
Do you want the car interior to be always clean and tidy? Do you understand that this requires regular cleaning, but spending money on car wash services is too expensive? Do you want to buy a car vacuum cleaner, but do not know how and which one to choose?
Who will benefit from the car vacuum cleaner
Auto salon leaves the first and greatest impression of the vehicle owner. Therefore, there is no need to argue about the importance of regular cleaning. However, when it comes to car vacuum cleaners, they will be especially useful in conditions where:
- the machine is actively used during the day;
- the car is often on country roads without asphalt;
- there are frequent passengers in the cabin, including children;
- animals are transported in the car, leaving hair on the seats;
- two or more family members have vehicles;
- upholstery of the car's interior and seats is made of textiles.
At the same time, the presence of a compact vacuum cleaner in any car allows you not to worry about small debris and dust.
Thanks to the constantly expanding functionality and a variety of attachments, modern models of car vacuum cleaners clean all types of surfaces, carry out different types of cleaning. And at the same time they are compact. Let's talk more about the variety of products on the market.
Types of car vacuum cleaners
The classification of car vacuum cleaners has several signs of division into groups. If you combine them into a single list, you get:
- by size: stationary and manual;
- by type of cleaning performed: wet and dry;
- for mobility: wired and wireless;
- by energy source: battery-powered, from a central power grid or from a car network.
Depending on the needs and scope of work, a different combination of the above parameters will be required.
Features of choice
Dimensions
A stationary vacuum cleaner is a large device with a long hose for cleaning. Typically, these models have high suction power and are able to cope with a large volume of work. This design allows you to eliminate contamination without bringing the body of the device into the interior of the car. In this case, it is important that the material from which the hose is made is resistant to temperature fluctuations, otherwise cracks may form.
Hand-held car vacuum cleaners fully live up to their name. They are small, fit easily into the interior and are held in one hand. With enough power to clean the engine compartment, they need constant cleaning of the trash can.
Cleaning type
Today, car vacuum cleaners are able to carry out both types of cleaning: dry and wet. Dry cleaning is the type of procedure everyone is used to. Dust and small debris are removed. The wet cleaning mode involves the elimination of spilled water, traces of melted snow, etc. This function is especially useful during periods of significant precipitation and during general cleaning.
There are also models that support both options.
Mobility
Mobility refers to how easily the vacuum cleaner can move around the cabin. Wired devices are limited by the length of the cord. Therefore, when purchasing, it is important to ensure that the power cord is of sufficient duration. Even when it comes to a stationary car vacuum cleaner.
Cordless options for car vacuum cleaners are mainly limited only by their own size and shape of the nozzle. With the right accessories, such equipment can clean all, even hard-to-reach, interior surfaces.
Power supply
Actually, depending on how mobile the chosen technique is, its source of energy changes. In total, there are three types of food:
- battery;
- vehicle internal network;
- household electrical network.
So, wireless mini models belong to battery-powered vacuum cleaners. Handheld vacuum cleaners can also be powered from a car network by connecting through a special adapter to the cigarette lighter. Less commonly, manual models are powered from a standard outlet. This energy source is used for stationary vacuum cleaners.
What to look for when buying
In order for the purchased car vacuum cleaner to be a practical purchase, and not spend money on a well-known brand, you will need to take into account not only your wishes, but also a few more tips. When choosing a model, you need to pay attention to:
- suction power;
- dust collector type;
- nozzle set;
- filter type;
- manufacturer.
The only thing we can say about the suction power is that the more this indicator is, the better the device will work. Optimally 40-75W, more than 75W will be required for heavy and regular pollution. At the same time, it is important to understand that this indicator falls as the dust collector fills with garbage. That is, to get the best results, you should clean the waste bin before each cleaning.
The dust collector can be in the form of a bag (made of multilayer material) or a container (most often made of plastic). The first type is most often used for dry cleaning of dust, the second-for wet cleaning. The container is convenient because the degree of its filling can be seen without removing it from the device.
The types of nozzles, filters and manufacturer benefits deserve separate sections in this article.
Bit Set
Nozzles are the second most important parameter (after power) of the choice. The fact is that the functionality of the vacuum cleaner itself depends on their quality and variety. The standard set includes attachments:
- for carpet, floor, ceiling, armchairs-has retractable bristles for stubborn dirt;
- for hard-to-reach places-elongated, sometimes with long bristles;
- for cleaning animal hair-has stiff bristles that can catch fine hairs and fibers.
Here, first of all, you should rely on your own needs. After all, if you do not feel the need for a huge set of attachments, there is no point in overpaying for it.
Filter type
The filter retains dust particles and debris inside the dust container, releasing cleaned air outside. In other words, the level of the final result and, accordingly, the price depends on its quality. According to the degree of purification, there are five varieties of this component:
- H10 - the thoroughness of separating litter from air is about 85%;
- H11 - garbage filtering quality is equal to 95%;
- H12 - dust separation efficiency is 99.5%;
- H13 - work is carried out with 99.995% accuracy;
- H14 - 99.9995% efficiency.
Filters are distinguished according to the principle of work:
- watery;
- fabric;
- cyclonic.
In the water filter, the air flow is passed through the liquid. Particles of dust and debris remain in the water and precipitate to the bottom.
The fabric type uses several layers of dense material. The air flow passing through such a filter leaves collected dust in its sections.
Cyclonic filtration is used in car vacuum cleaners with a plastic container for collecting garbage. In such a dust collector, the air rotates at a high speed, and the debris, under the action of inertia, sticks to the walls.
You can choose and buy a car vacuum cleaner at 130.com.ua with delivery across Ukraine.
Related materials
Car vacuum cleaners: Best Sellers
