Accessories for car seats the main types and purpose
A child car seat is necessary to protect children while driving. They guarantee safety, as they have a special design, which is specially designed in such a way as to protect the child from shock from injuries. Of course, when choosing such a chair, you need to consider a lot of different parameters: age group, child’s weight, fastening system, material, compliance with international standards, etc. But that’s not all, many parents don’t think about it right away, but there are a variety of additional accessories for children's car seats, which are used to provide the child with maximum comfort and protect the interior of the car.
Why do we need accessories
In addition to the child seat itself, it is recommended to purchase additional accessories for it, they may be different depending on the car brand, model of the seat, the needs of the child, etc. Accessories can have a variety of purposes, for example:
- additional elements of fixing the seat in the car-adapters, bases, belts, etc .;
- car care and seat protection-covers and special rugs;
- increasing the comfort level for a child who will be in a chair for a long time-pillows, lining on belts, liners, etc .;
- systems for organizing space in the cabin-organizers.
Accessories to protect the car seats from damage when using a child car seat
The manufacturers of the seats have taken care to ensure maximum comfort for the use of child seats, and offer accessories designed to protect the upholstery of the seats in the car from various mechanical damage and pollution.
Guides for easy installation of models with IsoFix
The IsoFix mounting system requires two special lock brackets. In the car seats there are special brackets in which to insert the brackets and press until the lock clicks. In some brands of cars, the brackets for fixing a child seat with the IsoFix system are located very deep between the seat and the back. And during installation, it is often required to exert maximum effort, which can lead to damage to the interior trim. To avoid possible damage, you must use special guides. They may come complete with a chair, or may be purchased separately. Their installation will significantly expand the space between the seat and the back of the chair, which will facilitate the installation of the child seat.
Safety mats for a child seat
They are designed to protect the interior from dirt and abrasion, scratches, dents and signs of wear. No matter how tightly the child car seat is fixed, it can still damage the upholstery of the passenger seats with prolonged use. To avoid this, special mats were invented that are as simple as possible to operate and are easily attached with straps. They are made of durable materials that are easily cleaned of dirt: any stain can be removed in a matter of minutes, immediately on the road. Some models of floor mats are compatible with the IsoFix system.
Platforms (bases)
To install some models of car seats, you can use the base or platform, which are compact stand-alone structures that play the role of an adapter between the car seat and the child seat. They are installed under the car seat, after which the seat itself is no longer attached to the car seat, but directly to the base, which provides the ability to quickly fasten the child seat, it only takes a few seconds. Another purpose of them, in addition to facilitating fixation, is to increase protection. As a rule, since the system provides the most reliable fastening, which will have maximum stability when driving.
Organizers
To protect the front back cIn order to store and conveniently store all sorts of little things, you can use a special organizer wrap. This is a practical thing with a large number of special compartments and pockets where you can put any little things you need on the road: baby wipes, toys, a hairbrush and much more. There are different models made of different materials, for example, it can be raincoat fabric, dense fabric, silicone and others. Such organizers are attached to the car seat with the help of special straps that allow you to adjust the size so that the cape is fixed as securely as possible. There are both standard models, that is, intended only for specific brands of cars, and universal ones suitable for use in any car.
Other useful accessories
- Mounts and adapters. They are intended for use with car seats (group 0+), which can also be mounted on wheelchairs. Thanks to them, you can transfer the child out of the car and install the chair on the stroller without removing the sleeping baby from the cradle. Before buying, be sure to check the compliance of the adapter and model of the stroller. The ideal option, when both the infant carrier and the stroller are of the same brand, then you can purchase a branded accessory that is 100% suitable and will provide a secure fit.
- Reflective curtains. During the ride in the summer, the child may be uncomfortable due to the blinding sun, this problem can be solved easily by installing a special protective reflective curtain. Many manufacturers offer lightweight curtains made of fabric, they are easily and quickly installed, protect the child well and are very convenient to use.
- Mirror. When an infant or child under 1.5 years old is transported in the car, the seat is often set up against the direction of travel (car seats of group 0+ or 0 +/1). If the chair is fixed in the back seat, then the parents cannot see what is happening with the child. In this case, it is useful to install a very simple accessory-a mirror. It is attached to the headrest, then it can be adjusted so that you can see the child through the driver’s rear view mirror.
- Extra pillow. If the child has to travel often and for a long time in a car in a chair, then a special pillow under his head will come in handy. It makes riding for a small passenger more comfortable and provides additional protection for the neck and head from injuries in the event of an impact. Typically, these pads are made of soft hypoallergenic materials, they can be machine washed.
- Footrest. The footboard should be made of durable plastic and have the ability to adjust in height so that the baby can have an optimal foot position. This accessory allows you to prevent leakage of the child’s legs so that it is as comfortable as possible on any train.
- A table for a car seat. This is another useful accessory that is attached to a child seat and is usually located on the lap of the baby. It can be used both for food and in order to place toys, drawing accessories or a tablet on it. In addition, such a table provides additional protection, as the child is more securely fixed.
Instead of a conclusion
All adults understand that the use of a specially designed chair in a car for a child is a necessity, since it is very important to guarantee him the necessary level of protection during the ride. All children under 12 years old must move in such a chair, and each parent wants to make such trips as convenient as possible for themselves and their children. And thanks to the use of special accessories, you can ensure comfort, properly organize the interior space in the cabin, as well as protect the upholstery from mechanical damage and dirt. When choosing an accessory for a child car seat, first make sure it is compatible with your car and seat, and be sure to look at the quality of materials.
In the store 130.com.ua you can buy a car seat for a child in Kiev, Odessa and Kharkov with various accessories from leading manufacturers. All seats are characterized by a high level of protection and comfort.
Materials on the topic:
Baby car seats and boosters: Best Sellers
