Car batteries with direct and reverse polarity-what's the difference?
Batteries for cars are of two types-with direct polarity and with reverse polarity. What is the peculiarity of these types of batteries and how do they differ between themselves?
Batteries of direct polarity and what they are
A car battery has a polarity, which can be understood by the location of the terminals on its surface (usually on the cover). Polarity is considered straight when the battery plus is on the left side of the battery, and the minus is on the right. At the same time, the battery should be turned towards the motorist (in many cases the terminals are closer to it, and if not, the desired side can be easily identified by the label). The terminals in the battery are indicated by the signs “+” (plus) and “-” (minus). You can buy a battery in Kiev, Kharkov, Odessa on 130.com.ua with delivery in Ukraine.
Reverse polarity batteries and what they are
Reverse polarity is when the “plus” in the battery is on the right, and the “minus”, respectively, on the left. Of course, also with the condition that the battery is turned to the front.
Difference between direct and reverse polarity batteries
The main difference between these batteries lies in the location of the “plus” and “minus” terminals. In appearance, such devices, as well as in terms of functionality, can be practically identical (especially if they are of the same brand and are intended for the same category of cars).
However, it is not recommended to put on a car that is designed for batteries of direct polarity, batteries, where the terminals are located differently. If the polarity is disrupted, the electronics in the car will not work, or even it may fail. Fortunately, the design of most cars simply does not allow the normal connection of batteries that do not fit in polarity.
In the process of selecting the battery, you can build on the country of the car manufacturer. If the country is Russia or, for example, Japan, then the car most likely needs a battery of direct polarity. If the manufacturer is the United States or Germany, then you will most likely have to use devices with terminals that are located opposite.
Having determined the difference between batteries of direct and reverse polarity, summarize the results in a small table.
| batteries of direct polarity | Reverse polarity batteries |
| General in these batteries | |
| Both types of car batteries work according to the same principles and can be the same in appearance if they are made by the same manufacturer | |
| Differences of these batteries | |
| The "positive" terminal on the battery of direct polarity is on the left, and the "negative" terminal is on the right | The "positive" terminal on the reverse polarity battery is on the right and the "negative" terminal is on the left |
| They are usually installed on Russian and Asian cars | Installed, preferably, on cars of American and European production |
Materials on the topic
Car batteries: Best Sellers
