How to choose autolamps
When choosing lamps for a car, consider the type of lamp (xenon, bi-xenon or halogen), lamp base, its power, glow temperature and service life.
Lamps -this is the main source of light in the car and it is important to choose high-quality car lamps for installation in the car, because the better the road will be lit, the it will be easier to drive in the dark and safer to travel. Looking for lamps for cars? Buy in Kiev, Odessa, Kharkov, you can at 130.com.ua. Delivery in Ukraine.
Type
To select lamps based on their type, click on the corresponding image.
More information about lamp types
Xenon lamps illuminate a wider part of the road, including the roadside. In any weather, you will clearly see the road, as the xenon light is much more intense than the halogen light. The service life of xenon lamps is almost 10 times longer than that of halogen lamps. On average, the halogenows have a service life of 300-400 hours, the same for xenon, the service life reaches 3000 hours! Xenon light is as close as possible to sunlight, respectively, the driver's eyes will be less tired.
Bixenon lamps contains all the advantages and disadvantages of xenon. The difference is that Xenon lamps are focused only on the low or high beam, and the bi-xenon lamp uses a mechanism that allows you to change the direction of illumination. If in your car split optics is not provided, then you should pay attention to the installation of bi-xenon.
Halogen bulbs are an improved version of ordinary incandescent bulbs. Together with an inert gas, some halogens are added to the refractory glass flask under pressure. These are mainly iodine and bromine vapors. This allowed to increase by several times the temperature of the filament and increased the light output. In addition, compared with incandescent bulbs, they have much more exploitation resources.
Base
To select lamps based on their base, click on the corresponding image.
| D1R | D1S | D2R |
| D2S | D4R | D4S |
| H1 | H10 | H11 |
| H13 | H27 / 881 | H28 / 880 |
| H3 | H4 | H4 / 9003 |
| H7 | H8 | H9 |
| HB1 / 9004 | HB3 | HB3 / 9005 |
| HB4 | HB4 / 9006 | HB5 / 9007 |
Glow Temperature
To select lamps based on their temperature of light, click on the corresponding item in the list.
More information about the temperature of the glow
When choosing a lamp should pay attention to their temperature of illumination. It depends on the color of the light flux and the illumination of the road as a whole. It is worth remembering that the rule “The more-the better” does not work here. The optimum glow temperature is 4300K. It is this light that has the best penetrating power in rainy or foggy weather. Plus, this light is closest to daylight and the best for perception.
DO NOT RECOMMEND
Lamp power
To select lamps based on their power, click on the corresponding item in the list.
With lamps buy
Daytime Running Lights
The main idea of a DRL is the designation of a car when driving in daylight with the aim of increasing safety. It has been proven that road crashes are significantly reduced with DRL or dipped beam on during the day. In comparison with the latest daytime running lights favorably with greater energy efficiency, service life, bright powerful glow, a positive effect on fuel economy.
Xenon and Bi-Xenon
Xenon in a car not only improves the aesthetic appearance of the car, but also significantly increases the lighting range and improves driver safety. The service life of xenon lamps is 10 times higher than halogen lamps.
Materials on the topic
