How to choose and store a car battery so that it lasts longer
When it gets cold, chemical processes inside the battery slow down, so the overall efficiency of the battery decreases. What should I do first?
First, check the battery voltage. And if it is less than 12.5 V, then you should recharge the battery. If the battery does not work at all and you are faced with the choice of a new one, then you need to take into account some nuances. Taking them into account, you will select the most suitable model specifically for your car and extend the battery life. you can buy a battery for a car in Kiev, Odessa, Kharkov with delivery in Ukraine at 130.com.ua.
Useful tips:
Forget about supposedly verified criteria. Now there are a lot of new features to which the old recommendations are not applicable. For example, the number of energy-consuming devices is growing, so the requirements for batteries are completely different.
Consider the modification of the car. For example, batteries designed for low power consumption are designed for older cars.
The technology used to produce the grille. For example, “stamping” is the most productive and optimal option. Due to it, it is possible to obtain a significantly longer service life of structures, improved energy intensity, more reliable protection against corrosion.
The production date does not affect the life of the battery. New technologies allow you to maintain the original characteristics for a long "idle".
For the production of modern batteries, AGM technology is used, which increases the number of discharge/charge cycles.
Materials on the topic
Car batteries: Best Sellers
