Gazer F225 review
Gazer F225 - one of the most powerful models among the entire range of this manufacturer. Here the advanced functional is implemented: the safety mode in the parking lot, the warning about the approach of objects, the "Antison" function, etc. In general, we get not just a DVR, but a powerful system.
Design Features
The difference between the Gazer F225 - the design of 2in1: DVR and security system. When manufacturers want to connect something, they do not always succeed. Something and needs to be worked out. Here, surprisingly, we get the perfection of each mechanism.
The design is a central unit with a screen and 2 cameras, which impress with its compactness. The latter you can set for recording in the salon or behind the car. The advantage is that the recording goes on separate channels, so you can choose several playback modes: immediately from all cameras or only from one.
A useful feature of the model is work in automatic mode: it turns on when the engine is started and turns off when the motor is disconnected. At the parking lot, the DVR will only record when the motion sensor is triggered. So, the battery charge is saved.
Full HD Camcorder Features
The standard equipment includes 2 video cameras, which are mounted using ZM tape. You can install them anywhere: in any part of the cabin or car casing. The manufacturer has finalized the design and you can now lock the cameras at a convenient angle.
You completely save in your system everything that is happening near your car. And the lens with a viewing angle of 160 degrees will help you in this. Due to the presence of DEWARP (distortion compensation), it is possible to avoid the appearance of the "fish eye" effect.
The video itself turns out to be clear and high-quality, thanks to the F2.0 aperture - recording in Full HD day and night. WDR technology allows you to remove too brightened, or, conversely, darkened objects.
Central block: what's new
The Gazer F225 has become so popular, primarily thanks to the recording of video from two cameras on separate channels. Records are stored in separate folders, which makes it easy to find the video you need. And at the same time, the device itself works quickly and without hanging. The powerful Ambarella A7 processor allows the system to process data at lightning speed. In addition, micro SDXC memory cards with a capacity of up to 128 GB are supported. Therefore, all records will be stored in your system - there will be enough space for everyone.
The central unit is presented in a compact case with a 2.7-inch display. The small size of the construction will allow you to install it in a convenient place for you, and it will not interfere with the driver's review.
Just 1 button and you activate the Speedcam mode, which warns of approaching objects. In addition, you get information about the necessary speed on this section of the road, the distance to objects, etc. There are voice alerts.
G-sensor - emergency file protection
The DVR is equipped with a G-sensor, which responds to sudden acceleration, braking or shocks. All files recorded at these times will automatically be protected from cyclic overwriting. So, you can be sure that the video you need will be saved in the device's memory.
In addition, you and you can protect the desired record with a special button. By the way, the manufacturer has provided a special remote control button, which can perform many functions. It is very miniature and is attached with the help of 3M Scotch tape. So, you can more conveniently, quickly and safely turn off the sound recording, control the DVR.
Intellectual Technologies
The Gazer F225 is distinguished for its advanced functionality. In particular, the device is equipped with intelligent technologies:
- — LDWS: controls the intersection of the band, for any deviation gives a signal.
- — FCWS: allows you to maintain the necessary distance with other road users.
Both functions can be adjusted individually, depending on your car and the conditions of your trip.
You can buy Gazer F225 in Kiev, Kharkov, Odessa at 130.com.ua with delivery across Ukraine.
Additional functions
Function "Antison": in a certain time period the signal will be activated. This helps drivers who often go on long trips. Such a signal will help to keep concentration on the road. In the settings you can set the desired frequency of such reminders.
The reminder about the inclusion of headlights will help to do it in a timely manner, without violating the rules of the road. The function is realized thanks to the built-in light sensor.
Parking mode. The DVR will start recording only when the motion sensor is triggered. After the motor is turned on, the device switches to standard mode.
The DVR Gazer F225 includes everything necessary for a comfortable, safe trip. Completely copes with its tasks and offers enhanced functionality.
Video recorders: Best Sellers
