What’s the Difference Between a Trimmer, Brushcutter and Hedge Trimmer: Tools for Lawn and Garden Care
When buying a grass trimmer, many people encounter unfamiliar terms: brushcutter, petrol trimmer, hedge trimmer... All of them look similar but serve different purposes and have different technical capabilities. To avoid buying a tool that’s too weak for thick vegetation — or overspending on unnecessary power — it's important to understand the key differences. This article explains how trimmers, brushcutters, and hedge trimmers differ and which tool is best suited for your yard.
Grass Trimmer: Lightweight and Precise
A trimmer is a compact tool with a curved or straight shaft and a spool of line. It’s ideal for regular lawn care — trimming edges along paths, around flowerbeds, fences, or trees. It's a complement to a lawn mower, not a replacement.
- Low power (300–800 W for electric models, up to 1.0 HP for petrol);
- Only suitable for soft, short grass;
- Compact and lightweight — easy to handle with one hand;
- Cutting element: nylon line (no blades);
- Best for small lawns and light-duty garden work.
Conclusion: if your goal is to maintain neat lawn edges, a trimmer is perfect. Just don’t expect it to cut through dense or tall grass.
Brushcutter: A Versatile Tool for Tougher Jobs
A brushcutter is a more powerful version of a trimmer, typically petrol-powered. It handles not only soft grass but also tall, dry, and thick vegetation. Brushcutters come with both line spools and metal blades or discs for dealing with weeds and overgrowth.
- Power output: 1.2 to 3 HP;
- Compatible with various blade and disc types;
- Rigid straight shaft with gearbox;
- Shoulder strap for weight distribution;
- Ideal for uneven terrain, fields, and roadside trimming.
Conclusion: if your plot is regularly overgrown with weeds, nettles, or you haven’t trimmed in a while — a brushcutter is the best solution.
Hedge Trimmer: For Shrubs and Woody Branches
A hedge trimmer is a completely different tool often confused with brushcutters. In fact, it’s not a cutter for grass, but a powered garden shear. It’s used to trim hedges, shrubs, and thin tree branches, working like a pair of scissors with a motor.
- Blade-style cutter instead of a line or disc;
- Operates like motorized pruning shears;
- Suitable for branches up to 2 cm thick;
- Available in electric, cordless, or petrol versions;
- Not a replacement for a trimmer or brushcutter!
Conclusion: if the main job is trimming bushes, hedges, or vines — a hedge trimmer is the right tool.
Comparison Table
| Parameter | Trimmer | Brushcutter | Hedge Trimmer |
| Cutting type | Nylon line | Line / blade / disc | Blade |
| What it cuts | Soft grass | Tall grass, weeds | Shrubs, branches |
| Power source | Electric / battery | Petrol / sometimes electric | Electric / battery / petrol |
| Weight | 2–4 kg | 5–8 kg | 2.5–5 kg |
| Best for | Lawn edge trimming | Heavy-duty vegetation | Hedges, bushes |
How to Choose: Match the Tool to the Task
If your yard is mostly lawn — a simple trimmer will do the job. If it's overgrown with thick weeds or tall grass — go with a brushcutter. And if your focus is trimming shrubs, grapevines, or hedges — pick a hedge trimmer.
At 130.com.ua, you’ll find a wide range of trimmers, brushcutters, and hedge trimmers from trusted brands — including electric and petrol models. Our experts will help you choose the perfect tool for your yard, whether it's a small garden or a large rural plot.
Lawn mower EGO LM1903E-SPBuy40999 ₴ 39998 ₴
