Повербанки
Close
TOP-3 lawn mowers. Lawn mower rating 2022
Lawn mowers were originally designed to tidy up lawns. But our gardeners and summer residents successfully use these devices simply for cutting grass (as well as bushes-if power permits), sometimes processing hilly, heavily overgrown areas. Depending on the type and design, you can find several variations in the names of grass cutting devices.
  • Trimmer
  • Cutting machine
  • Motokosa
  • Mechanical scythe
  • Mower
  • Raiders (mini tractors)
When choosing a lawn mower, you should pay attention to the following factors:
Which area will be treated? Estimate its area, relief, degree of littering. What other vegetation is on it? What type of grass grows-soft, hard, short, or quickly grows to a meter height? It depends on the type of lawn mower that suits you, the required power, maneuverability and maneuverability.
For example, if you have a "real English lawn"-a perfectly flat open area, without trees and bushes, with dense short grass, and you cut it regularly-a self-propelled four-wheel lawn mower or a gas trimmer will suit you. On uneven ground (there are bumps, mounds), wheeled lawn mowers work well. For cutting grass in a small area, complex shape, overgrown with hard grass, shrubs, choose a manual lawn mower (trimmer). For a small but clean area, an inexpensive electric trimmer will do.
Who will use the device? For men, almost any model will do. The main thing is that it fits the height. But if a woman or an elderly person has to mow the grass, the weight of the lawn mower becomes of great importance (note that the mass of the filled grass collector will be added to the weight of the device itself), ease of maintenance.
Model equipment. What is included in the kit, knives or fishing line, or both? Does the manual lawn mower have a belt and which one?
Let's take a look at our TOP-3 lawn mowers that are the most popular among the customers of our online store. Our rating looks like this:
AL-KO Comfort 40 E
Multifunctional German lawn mower with 3 in 1 function: mowing, collecting and mulching. The small non-self-propelled lawn mower Silver 40 E Comfort Bio Combi from the well-known German company AL-KO is designed for frequent grass cutting on small lawns. Since this model is electric, that is, its range is limited by a network cable, it is most advisable to use the tool on areas not exceeding 600 m2. Convenient and reliable, the Silver 40 E Comfort Bio Combi has a beautiful modern design and is easy to use. Distinctive features are compactness, lightness (19 kg of weight) and low price.
The Silver 40 E Comfort Bio Combi is equipped with a quiet and environmentally friendly 1.4 kW electric motor. This is a modern factory engine from the manufacturer, which is easily turned on with a simple push of a button and is well protected from overloads. The cable is placed in such a way that it does not get into the area of the cutting tool. If necessary, you can use an extension cord.
You can set the desired cutting height with the Silver 40 E Comfort lawnmower with one hand movement, without the use of special tools, since it has a convenient central spring adjustment. The tool has the ability to set the cutting height of the grass in several positions, with a minimum height of 28 mm and a maximum of 68 cm. The grass cut, regardless of its hardness or moisture, is very even, which is explained by the optimal design of the knives, their placement parallel to the surface and the presence of a strong stable axis. The cutting width is constant at 40 cm, and thanks to the narrow front, it is possible to work under trees and under bushes.
When mowing with the Silver 40 E electric mower, the grass, together with the air jet, is placed in a large grass bag with a capacity of 43 liters. The numerous holes in the grass catcher box are designed so well and thoughtfully that they create air channels and do not become clogged with cut grass. Clean holes play a very important role for a quality, even cut. For quick removal and installation of the tank, the EasyClick system patented by AL-KO is installed. It also washes and cleans well. There is a fill indicator-a small flag that is raised when the tank is empty, and rises as it fills up.
The light electric lawnmower AL-KO Silver 40E Comfort BioCombi not only collects grass in grass catchers, it also mulches it-it grinds it like a meat grinder. Chopped grass is the best organic fertilizer that can be used in the household.
AL-KO Classic 3.82 SE
AL-KO's Lightweight Electric Lawnmower Classic 3.82 SE is designed to cut grass on small lawns-up to 5 hundredths. The efficiency of the tool is excellent, and the physical and financial costs are minimal, which makes it very popular in the household electric mower market. The machine is compact and fast, moving in a straight line, thanks to solid wheel axles. It is easy to control and maneuver.
The power plant of the AL-KO Classic 3.82 SE is a modern electric motor with a power output of 1.4 kW. It is well protected from unexpected voltage drops in the network, does not require maintenance and constant refueling of gasoline and oil. The motor is quiet, environmentally friendly, turns on at the touch of a button. The only drawback is the connection to the power grid, but this does not cause inconvenience on small house lawns.
The cutting system of the AL-KO Classic 3.82 SE is well thought out, the width of the passage at a time is 38 cm. The cutting height of the grass is adjustable in the range from 2 to 6 cm. The adjustment is made by raising the wheel axle and is fixed in three positions.
Alco's Classic 3.82 SE electric lawn mower has a durable polypropylene body that is resistant to corrosion and a large grass box. The advantage of the grass catcher is that when it is full, the engine automatically turns off. The container can be easily removed and washed. Safety arc switch with cable fixing system. XL tires for optimum ride comfort.
Careful mowing of the lawn edges due to the special geometry, in which the wheels do not protrude beyond the line of the body (cutting mechanism)-this allows you to mow grass along fences and walls.
With its built-in handle and light weight, the 3.82 SE is very easy to transport and store.
The 37-liter polyurethane grass collector allows you to collect a large amount of chopped grass. Its durable body can be easily washed with water and completely cleaned of the remnants of the grass killed with a knife.
The control knob is aluminum collapsible and takes up minimal space during transportation or storage. Fastening with clamping handles that do not require the use of tools. On the right side of the control handle is the start button and the knife drive lever. The equipment is started with one click on the "Start" button. The lawnmower has a protection system against motor overload and power outages. Automatic shutdown of the engine when the grass catcher is full ensures a comfortable process of working with the equipment.
The cutting mechanism of this model is a sharp steel knife with a diamond sharpening and a special shape for more efficient grass cutting.
Zipper ZI-BRM508
Using the Zipper ZI-BRM508 petrol lawn mower, the gardener will tidy up medium-sized lawns, trim the grass, form a vegetation cover for decorating the site and active pastime.
The high-performance 4-stroke type gasoline engine has an impressive power reserve for cutting tall and dense grasses, coarsened weed stalks. High-quality components led to a long motor resource and the absence of serious breakdowns.
All-wheel drive provides good cross-country ability and driving on hills, the car does not need to be pushed, the user only changes direction, indicating the motion vector.
A capacious 65 l container allows you to cut for a long time without technological stops. Improved air venting through the fabric base gives maximum filling of the basket.
The cutting mechanism covers a half-meter strip of the cultivated area, ensuring faster implementation of the planned activities.
For the processing of scraps, a mulching function is provided, which solves two problems at once-fertilizing the soil at no additional cost and eliminating waste from the site.
Due to a special nozzle that drops organic debris along the moving mower, it is convenient to mow vegetation near the edges of lawns, curbs, fences, walls.
The manufacturer recommends using this version of landscape gardening equipment on lawns whose size does not exceed 20 acres, in which case the load on the motor and cutting unit will be optimal and will not cause premature failure.
Related content:
Lawnmowers, trimmers and brushcutters: Best Sellers
