TOP-3 car compressors. Autocompressor rating 2022
The advanced modern driver does not need to be convinced that a hand pump is good only for a bicycle. And you can quickly pump up a flat car tire only with the help of an electric compressor.
After all, there is hardly a hardened lover of physical exercises and long hard work-and this is exactly what awaits those who do not have an autocompressor in the trunk or garage.
But not all car owners are capable of choosing this device and deciding which car compressor is best for a car.
When choosing a car compressor, you should pay attention to the following parameters:
Performance: this is the main parameter characterizing how much air the device can compress per unit of time. Measured in l/min (m3/min, m3/h, etc.). It depends on how quickly you can pump up the wheel. Most average models have a capacity of 27-35 l/min. This is enough to inflate an R16 tire in a few minutes.
Connection type: Most electric car air compressors designed for tire inflation in cars, SUVs and crossovers are equipped with a standard power connector for connection to the cigarette lighter socket. More powerful versions of car compressors can be equipped with special crocodile terminals that are connected directly to the car battery-this is done specifically to avoid possible overloads in the car's on-board electrical network.
Cord length: perhaps the biggest disappointment in a car compressor can be the discovery of the fact that the cord is simply not long enough to reach the rear wheels of a car. In addition to the length of the cord, also evaluate its rigidity-with a strong stretch, a hard twisted cord will pull the plug or alligators out of place, a conventional type cable is preferable, although it is not so convenient to store
Pressure Gauge Accuracy: It's difficult to judge the accuracy of readings without a reference gauge, so pay attention to how well it reads the scale first. On small pressure gauges, the arrow can easily overlap the divisions-a run-up in pressure up to 0.2 bar between different wheels will be inevitable.
Uptime: This should be considered in conjunction with performance. For example, if you have an SUV or crossover with high-profile 16-inch tires, a low-power compressor will not only pump the wheels for a very long time-it will also overheat.
To facilitate the choice, we have selected the TOP car compressors, which included the most popular and best-selling models.
He will help you understand the nuances of choosing this technique and buy for yourself one of the autocompressors, the rating of which is presented below.
Vitol K-70
Reliable and inexpensive compressor for use in the car and at home. Vitol K-70 is recommended for wheels with a diameter up to R16 inclusive, but it is able to inflate wheels with a larger diameter. Quickly inflates the wheel of a car, SUV and minibus. It will come in handy for lovers of active pastime when pumping equipment for sports and recreation.
Benefits:
  • Powerful 100% copper coiled rotary motor
  • Reliable and easy to use
  • Deflator-a device that allows you to reduce the pressure in the wheel
  • Power: 360 W.
  • High productivity-90 liters per minute
  • Fuse, for surge protection
  • Convenient fabric pouch for transportation, with rubber inserts at the base to prevent slipping in the trunk
Complete set:
  • Compressor
  • A set of nozzles for inflating balls, boats, bicycle tubes. Two sets of adapters made of brass and plastic
  • Power cables 3 m
  • Curled hose 6 m
  • Storage and carrying bag
  • Instruction manual.
Berkut R20
The BERKUT R20 is a compressor for big tires on big cars! It is interesting for owners of sports and specially prepared SUVs who participate in special off-road competitions. The advantages of this model are fast pumping speed and high power.
The BERKUT R20 compressor is connected directly to the battery terminals. There is a stable off-road platform and a built-in air purification filter. Equipped with a universal coiled extension hose with an accurate pressure gauge and a DEFLATOR valve for precise adjustment of tire pressure.
Features:
  • Piston-type pump that does not require lubrication
  • Wear-resistant PTFE piston ring
  • Durable stainless steel air valves
  • Aluminum alloy slave cylinder
  • Permanent magnet motor
  • Automatic overheat protection
  • Dust-proof design + cleaning filter
Specifications:
  • Power supply: 12V
  • Maximum current consumption: 30 A
  • Maximum pressure: 14 atm (kg/cm2)
  • Working pressure: 0-4.1 atm (BAR)
  • Continuous operation time: 60 min
  • Maximum output: 72 l/min
  • Operating temperature range: -30 °C +80 °C
  • Noise level: 69 dB
  • Universal hose length: 7.5m
  • Power cord length: 2.4 m
  • Protective fuse: 40 A
Complete set:
  • High precision double scale pressure gauge
  • Bleed valve-DEFLATOR for pressure regulation
  • Quick coupling for wheel nipple
  • Handy bag for storage and carrying
  • Additional fitting kit
  • BERKUT VT-300 boat inflation adapter
Belavto BK45 Zubr
The Belavto Zubr BK45 car compressor has increased power and is equipped with two cylinders, which allows it to inflate car wheels, boats, sports equipment, etc. twice as fast.
This compressor has a large comfortable handle with a soft coating, and its body is reinforced with a metal frame. From below, the two-cylinder autocompressor Belavto Zubr BK45 relies on rubber shock-absorbing rubber feet, which improve its durability and absorb vibration during operation. It is also worth noting the high-quality power cable, and the cores, which are made of 100% copper, which ensures durable and trouble-free operation. High-quality clips ensure a secure fit on the battery terminals.
Included 5.7m red spiral hose makes it easy to use the compressor when inflating tires of large vehicles, and a built-in pressure gauge with a release valve allows you to control the pressure level. The high performance of the Zubr BK45 compressor is 90 liters per minute, which significantly exceeds the performance of two-piston compressors from other manufacturers.
Key features and benefits:
  • Reinforced body protection with a metal frame.
  • High-quality motor winding made of 100% copper allows the motor to work for a long time without overheating.
  • The power cable is 100% copper and is fused with a 30A fuse.
  • The spiral hose is made of high quality frost-resistant PU.
  • The presence of a high-precision metal pressure gauge with additional rubber protection.
  • Equipped with a deflator to release excess pressure.
  • The compressor is equipped with rubber feet to eliminate excessive vibration.
  • Natural rubber hose
  • The metal connector is comfortable and reliable.
  • Comfortable soft grip handle for easy carrying of the compressor.
  • Waterproof bag made of high quality material.
  • The clips are made of high quality material, which allows them to be effectively fixed on the battery terminals.
  • Additional adapters and fuse included.
Complete set:
  • Compressor with precision pressure gauge
  • Copper power cable 2.4m
  • 5.7 m durable rubber hose
  • Battery clamps with fuse
  • Adapter kit
  • Waterproof bag for easy storage and transport
Related content:
Compressors and pumps: Best Sellers
