Protective cover-awning on the car: how to choose the right
Every car owner wants to protect their vehicles from dust, dirt, possible damage. Of course, it’s much easier to do this with your own garage or with an attached parking lot nearby. But what about the “lucky ones” who have a yard or ordinary parking without a roof at their disposal?
Car tent is designed for long-term storage of the car and protect it from precipitation, scorching sun, dust and dirt. Such a universal accessory will help you to extend the life of the paintwork, as well as eliminate the negative effects of ultraviolet radiation.
What to look for: basic features
First you need to decide what you need case on the car : for transportation or storage. If the second option is already clear, then the first question may arise. This group is used only in rare cases, often only car services, wholesalers of vehicles.
When choosing awnings, consider the following nuances:
- Size. There are universal models that are suitable for all cars, but you can choose a specific size: S, M, L, XL. Each parameter corresponds to a specific transport for which it can provide all protective conditions.
- Cloth. The main requirement is high air permeability. A quality case should not allow storage of moisture under it, because the constant contact with water wears the car cover faster, especially if there is a frost. Pay attention to models that do not allow water, dust, dirt, but can guarantee good air circulation.
- Sewing. The quality of the fabric is not the last selection criterion. So, all seams should be made of reinforced filaments consisting exclusively of polyester. Such material is able to provide high resistance to various loads. Double stitching is another sign of high-quality tailoring.
- Additional items. It is not recommended to choose a model with transparent fabrics in the windshield area, as a rule, such a material does not allow air to pass through, and therefore accumulates condensate that creates all the conditions for the appearance of rust.
It is recommended that there be a special rubber band at the bottom of the case that would allow the accessory not to slide down and protect it effectively. The reverse side of the awning should be equipped with a special lining, designed to protect the car's cover from possible scratches when touching the material.
Multi-layered models are the most practical because they provide a soft fit for the car and keep the coating in perfect condition. Some accessories include a zipper so that you can easily access the trunk. You can buy a car awning in Kiev, Odessa, Kharkov with delivery in Ukraine at 130.com.ua.
Materials on the topic
