Automobile awning-foil case
Vitol XL Polyester + Aluminum foil car awning Do you easily manage to park the car in the shade to protect yourself from incandescence and overheating in the middle of summer? Can you quickly organize a decent parking for a car without your own garage or away from it during long journeys? Most of these problems will be solved automatically if you buy an awning for a car. Automobile cover (tent) today is high-quality materials, special protective layers, carefully thought-out cut, ventilation channels, maybe with a soft lining and even an additional coating of aluminum foil. Why “wrap” cars in foil?
The metallic coating of automotive foil-covered tents works by effectively combining the special properties of aluminum foil — exceptional barrier qualities, lightness, durability, and environmental friendliness. Maximum opacity and impermeability make such protective covers a reliable barrier from sunlight, moisture, gases, odors, dust and dirt. Automobile awning with a coating of aluminum foil has a high reflectivity and thermal insulation properties that protect cars from high (or low) temperature, do not allow to increase (or decrease) the temperature in the cabin. Corrosion resistance, thermo-, hydro- and vapor-insulating properties of a foil coating make it possible to achieve reliable protection against external influences, environmental influences and precipitation. Its high quality materials are also resistant to mold and mildew. The special double protective layer that such covers on the car have is an effective protection from the sun, precipitation, adverse weather conditions, dust, dirt, insects, animals, tree resins and other external influences. you can buy a car tent in Kiev, Kharkov, Odessa at 130.com.ua with delivery in Ukraine.
The practicality of such car covers tents is provided by a safe and soft material that does not damage the surface of the car. Double seam increases the strength and durability of the product, and due to the driver’s zipper, you can get into the salon without removing the cover. In addition, the foil coating is flexible and ductile. Such car tents with foil coating (such as those presented on 130.com.ua) easily “fall” on the surface and take the necessary form. In addition to all this, it is worth noting its exclusive design with a chrome effect and an unobtrusive metallic shade.
If you are still tired of sitting down in the summer in a sweltering and red-hot, and in the winter in the ice cabin, cleaning the car from fallen leaves, branches, resinous tar gum, snow and icing, fighting the results of the activity of insects and animals, then it's time get a car case and pay attention to practical foil models. Contact our store and choose a suitable cover for the car, the price of which allows you to put this necessary accessory in the trunk of many cars.
TOP-3 covers for cars
Best car covers
Looking for a quality and the best autoentents? This rating of autoentents is made on the basis of such parameters as: high demand with positive feedback from our customers, high-quality manufacturing — absence of factory defects and service calls, and official warranty and post warranty support in Ukraine.
Car cover Vitol JC13401 XL
Features:
  • ★ For a jeep, minivan
  • ★ Size 4830x1960x1450 mm
  • ★ Cotton lining
Car cover Vitol JC13402 L PEVA + Non-PP
Features:
  • ★ Cotton lining
  • ★ Size 4570x1850x1450 mm
Car cover Elegant 100 271 SUV POLYESTER M
Features:
  • ★ Size 4400x1850x1450 mm
  • ★ water-repellent material
Materials on the topic
