Installing a subwoofer under the seat or in the trunk
The active subwoofer under the seat has become particularly popular because of its practicality and space saving. Such a device takes up little space and is almost invisible. They can also be mounted in the trunk, if in the future you do not need to additionally use this place. Please note that in this case the frequency of the sound will become lower.
A car subwoofer can be with a closed box-it has the easiest way to install. It is almost impossible to make any mistakes in installation and connection.
Stripe box-you can create any pressure in the system. But for beginners, such a device is not suitable, because for the proper installation will require some knowledge and experience. For example, you need to provide protection from external conditions.
Install the subwoofer under the driver's seat
In order to fix the subwoofer for the car, the aluminum profile is best suited: it must first be screwed to the floor of the car.
Please note that in some cars in this place there is a fuel tank. When drilling, you need to be very careful and if possible use only short screws.
Most often bundled with a subwoofer is a bundle of wiring, but for better reliability it is better to choose a copper cable: it will last longer.
We begin to carry out the power cord from the distributor and continue to run along the pedals, then along the door and under the seat.
To get the right signal, car subwoofers use the amplifier's line-level outputs, the cable is soldered in length.
That's it. Now you can improve the sound quality of the music, and if you turn up the volume, the driver's seat will become a massage chair. You can buy a subwoofer in a car in Kharkov, Odessa, Kiev with delivery in Ukraine at 130.com.ua.
Watch car subwoofer video reviews
Materials on the topic:
Car subwoofers: Best Sellers
