How to choose heated seats
Heated seats at times increases comfort when traveling in the cold season, plus a long ride being on a cold seat is dangerous to your health, and using heating you also take care of your health. Heated seats can be bought with delivery in Ukraine in Kharkov, Kiev, Odessa on 130.com.ua.
Heating Type
To select heated seats based on its type, click on the appropriate image.
More information about the types of seat heating
Seat heaters are of three types-heated in the form of a seat cover, heated cape and recessed heating. All types of heating have their advantages and disadvantages.
Heated Covers. Heated seats in the form of a cover are good because they are very comfortable and look like “relatives” in the cabin. Such heating can be used all year round-in the cold season they will warm, and in the warm season they can protect the seat from wear, since the heating itself can be turned off. The disadvantages can only be attributed to the fact that they cannot be immediately removed from the seat, if necessary.
Heated capes. The advantage of heated capes is that they are mobile and can be easily removed and mounted on another seat at any time. They also partially protect the seat from wear.
Built-in heating. Built-in heaters are installed under the seat trim. Due to this, after installation they are completely invisible. The disadvantage is that they are not easy to install by yourself and it is recommended to contact a specialized service center, but these are additional costs. But if the question is not in price, then recessed heaters are a great option.
Heating Element
To select seat heating based on the type of heating element, click on the corresponding image.
More information about heating elements
The most common heating elements in seat heating are: wire heating element and carbon fiber.
The wire heating element is the most popular, since under normal use it can last for a long time and reliably, but if it is often bent, the wire can break. After that, the heating will no longer be heated.
The carbon fiber heater is more reliable, as it is subject to various deformations without any consequences. Ie, it can be bend, bend and fold into a tube-it will work exactly. Of course, if it is torn apart, it will fail, but accidentally breaking apart the heating is unrealistic.
The heating temperature of both heating elements is about the same, and the heating time depends on the thickness of the heating upholstery.
Heating Control
To select seat heating based on the presence of a heat regulator, click on the appropriate image.
More information about the heating controller
The heating control is one of the most convenient additions to seat heating. With it, you can adjust the degree of heating of the seat and, if necessary, turn it off without pulling the plug out of the cigarette lighter. This will eliminate quick wear of the cigarette lighter socket due to its frequent use.
The lineup
With Heated seat buy:
cigarette lighter sockets
Not all cars are equipped with several cigarette lighter sockets, and in the current realities, having many useful devices working from the cigarette lighter is difficult to do with just one socket. Using the splitter of the cigarette lighter socket, you can simultaneously connect several devices to the cigarette lighter, for example, heated seats, a radar detector, a DVR and a telephone charger.
Materials on the topic
Seat warmers: Best Sellers
