Is it realistic to save fuel when driving “smoothly”
Saving gasoline is a completely natural desire of any car owner. It happens that you ride “smoothly” for six months, you try to save, and the flow rate below 13 does not fall. But what if the matter is not in the car itself, which, according to the driver, eats a lot, but that you overfeed it yourself.
The secret is simple: try to avoid situations where the engine will burn fuel. To do this, you must observe a certain inertia of the trip: do not slow down again, so that you can not accelerate again, forcing the engine to eat more gasoline.
Set a goal to drive as evenly and smoothly as possible, to do this, accelerate less and slow down. To accomplish this task, you need only forecasting, distance and learn to feel the car. Each solution has its own characteristics.
Prediction
If you know that the speed bump is ahead or you see that the red color at a traffic light is on, it makes no sense to drag the braking process down to the last: you still slow down, just do it later and sharply. On the contrary, it is better to start smooth slowdown in advance.
And if there is a traffic light ahead, then you can slowly roll towards it, avoiding the most wasteful stop at the red color and drive up to the green signal. The ability to predict comes with experience. The timer at most modern traffic lights serves as an assistant.
Car feeling
The most frequent situation when we have to slow down is a turn. Some drivers include a brake light even where this can be avoided. Therefore, they need to accelerate again, losing fuel. Other car owners pass the same sections of the road without braking, but within the necessary safety.
Here the decisive factor is the feeling of the car: an experienced driver will be able to choose the right area for driving, and he feels the grip better.
A good example is travel in areas with winding roads. Residents of such cities, even in the old van can drive smoothly and without a sudden slowdown. To acquire the necessary skills, you can take a few lessons in a driving school or attend rolling karting.
Distance
In order not to slow down once again, you need to monitor the distance. It is necessary to learn in advance to anticipate areas where you need to slow down, for example, if the front car turns.
In any case, you need to experiment with the style of driving and look for the most economical way. A smooth ride is a comfortable way that does not force you to give up all the functionality of a car, but will help reduce fuel consumption.
Related Content:
