How to quickly defrost car windows
For car owners, whose transport even in the winter is stored on the street, there is a problem of quick defrosting of windows. After all, even if the interior warms up, and the windows are still covered with a layer of ice, it is not possible to start the movement: only supermen in films will be able to drive a car without a view of the road.
Modern models of cars began to be equipped with a windshield blowing system with air from the stove. Special technologies are also provided for heating the rear window or rear view glass. However, almost every driver is faced with the problem of windshield icing. When you park the car, the cabin has a positive temperature, after the car cools down, the moisture settles on the glass from the inside, and a layer of ice appears outside.
A few tricks to defrost windows quickly
Experienced drivers already have a couple of their secrets in stock how to quickly defrost the windows of a car. For newbies, this is a global problem that can take a lot of time to solve. Several options:
- Special fluids. You can buy a ready-made version, but you can do it yourself. For example, take ordinary vodka and pour over the frozen surface. You can use any alcohol. For convenience, pour liquid into the sprayer. Looking for a windshield defrosting fluid? Buy in Kiev, Odessa, Kharkov, you can at 130.com.ua. Delivery in Ukraine.
- Turn on the engine and the stove, auxiliary elements that will speed up the defrosting process.
- Dissolve salt in warm (not boiling water) water and spray on the glass. Or you can simply sprinkle salt on the iced glass.
- Use a special film in advance to protect the glass from freezing.
A regular bottle of glass detergent may be suitable as a dispenser. It is not recommended to use a scraper, because it can leave cracks and pour boiling water over the surface, which can also cause cracks.
Related Content:
