Proper car body care
Most car owners dream of keeping their car looking perfect for as long as possible. The point is that this requires a lot of effort, because the state of the paintwork of a car depends on how carefully it is looked after.
Regular maintenance and prevention will help protect the paintwork of the car body from premature wear. There is a huge range of different products to help you take care of your car's appearance.
Car body car body care
It is impossible to properly clean the body without a special tool. When cleaning the machine with a sponge and water, you will only be able to remove the top layer of dust. Long-term dried dirt will still remain on the body, which will subsequently negatively affect the coating of the car.
For the correct and complex treatment of the car body, you need to navigate care products and understand exactly what they are intended for, because there are not universal products that are both suitable for paintwork and for the car interior.
Paintwork
Car shampoo is the most common car body care product among motorists. In the composition of such shampoos there are additional polishing elements that clean the car and additionally give shine. There are several types of them with different properties-anti-corrosion and with a polishing effect. Car shampoos are relatively inexpensive, but at the same time they perfectly clean the body and cover it with a thin protective film that protects the paintwork from the environment.
Cleaner shampoo is more effective than simple car shampoo, as it copes much better with removing sufficiently strong body contaminants. It can also be used as a regular car shampoo by simply adding water and washing the car completely. In such cases, we recommend using a regular car shampoo, since it is much more economical. For more serious contaminants that the above products could not handle, you can use anhydrous washes.
Car body polishing
Cleaning polishes help to eliminate minor damage in the form of scratches, irregularities and give the car its original appearance. And also cover it with an additional layer to protect it from external factors.
But it is not recommended to abuse the body polish, as they can partially remove the top layer. At on average, a conventional car body coating can withstand about fifteen of these procedures.
Protective polishes interact exclusively with the top layer, covering it with a thin film that performs protective functions. You can apply these products only on a surface that is free of any damage, otherwise you will accelerate the spread of rust on the car body.
Wax polishes can mask small scratches and stains and give it a short shine. Among the disadvantages of such funds: short duration of action, complexity of application and distribution over the body, since they are quite thick in consistency.
Color-enriched and express polishes will help to quickly give the paintwork an attractive look, but they will not provide any protection to the car body.
Caring for headlights and auto glass
Using special cleaners for glass and headlights, you can more carefully and effectively clean their surface from dirt. Almost all cleaners come in the form of sprays, which you just need to spray on the surface and wait until the components of the cleaner remove contamination. This technique helps to remove even the most difficult stains such as smog, nicotine, grease, insect residues, oil stains and without & leaving streaks and greasy stains.
To maintain the car body in excellent condition, you must regularly use high-quality auto care chemicals, then you can keep its appearance for a long time.
In addition to car body care products, there are also specially designed car interior cleaning products. The range of auto chemical goods can be very diverse:
- Car interior cleaners (gently remove plaque and dirt)
- Car interior polishes (restore the original appearance of surfaces and protect against damage)
- Car interior restorers (eliminates minor damage, and does not masks them)
- Kits for car interior & nbsp;
At 130.com.ua you can find a large assortment of car care products.
Related Materials
