10 basic rules for car battery operation
It is noticed that car owners spend a lot of money for nothing. To avoid this, you need to use a total of 10 recommendations for the correct operation of the battery.
Car battery
The Right Choice
You need to pick up the battery in accordance with your vehicle. The manual of the car has a page with the necessary battery parameters: nominal capacity, starting current, etc. The main thing is to find out the required capacity parameter. If the selected battery does not match this value, it will be constantly discharged or recharged. you can buy a car battery in Kiev, Odessa, Kharkov and with delivery in Ukraine at 130.com.ua.
Do not forget about the inspection
You need to regularly inspect the battery. This will allow to detect any mechanical damage, scratches or cracks. They can occur due to freezing of the electrolyte, due to frost, etc.
Remember safety when you “light a cigarette”
Sometimes we are confronted on the road with a situation when we need to give another driver a "light" or find ourselves in the role of those who need this help. And if for old models that are not yet equipped with a large number of electronics, this is sufficient, then modern cars require more.
For example, do not leave the ignition switched on on the donor vehicle. Otherwise, the electronics may stop working. Please note that during the connection, you must first connect the minuses, and then the pros, and when disconnecting, do everything in the reverse order.
Electrical Status
Any, even the smallest, failure of a generator, relay or other mechanisms over time leads to a gradual or abrupt discharge. If you notice that the starter is not spinning very well, and there are no other reasons for discharging the battery, then it is better to immediately consult an electrician.
Keep an eye on charging
Charge the battery on time and do not allow it to fully discharge. To do this, do not forget to turn off the interior lighting, headlights, do not use electrical equipment for a long time.
Check battery mounts
Due to the fact that our roads are not in the best condition, the car is constantly subjected to shaking, which can weaken the battery over time: the battery will jump off its place and be damaged.
Keep your purity
Clean your battery and terminals quickly. If oxide appears, it may be a signal of not very tight contacts.
Start the engine properly in the cold
Try not to turn on the starter for more than 30 seconds at a time. If you have a manual transmission, then at a temperature below 20 degrees, disengage the clutch (if in an automatic transmission).
Periodically charge the battery
If there are no obvious reasons for discharging and you use the car only occasionally, and at short distances. In this case, the battery is not fully restored.
Do not forget about the service station
If you do not understand the batteries, but want to maintain its good condition-contact the experts. After all, it is much easier and more convenient to avoid many mistakes.
TOP-3 car battery
Best car batteries
Looking for a quality and the best batteries for cars? This rating of batteries for cars is made on the basis of such parameters as: high demand with positive feedback from our customers, high-quality manufacturing — absence of factory defects and service calls, and official warranty and post warranty support in Ukraine.
Accumulator battery Varta Silver Dynamic AGM 6CT-70AZ
Features:
  • ★ location of the terminal - "+" on the right
  • ★ starting current - 760 A
  • ★ capacity 70 Ah
The battery in the car FIAMM Titanium Pro L4B 85P
Features:
  • ★ Capacity 85 Ah
  • ★ Starting current 760 A
  • ★ "+" On the right
Car battery EXIDE AGM 6CT 95 Ah
Features:
  • ★ starting current - 850 A
  • ★ capacity 95 Ah
Materials on the topic
Car batteries: Best Sellers
