How not to freeze in the winter. Types of seat heating
In the winter season, heated seat heating is becoming increasingly popular. This is a very necessary thing, not only for those motorists who spend a lot of time on the road, but also for those who appreciate the warmth and comfort of a car. In addition, buy heated seats will be very useful if the leather interior in the car. The price for the built-in heating function in a car can go up to $ 400, while the kits that are available on the market are sold much cheaper and are not inferior in quality, and there are more than enough options to choose from. At the time of purchase it is very easy to choose the best option, depending on the conditions of use and price.
Heated seats
What are seat heating
At the moment, there are three main options for heating: built-in heating, in which heating elements are mounted under the seat upholstery, capes that are placed on top of the seat, and heated covers. All built-in seat heating fall into the first category and are the most interesting options, since they absolutely do not change the car's interior. Of course, covers and capes are much easier to install, they can be reinstalled from one machine to another, but this is not always the best option. You can buy heated seats with delivery to Kiev, Odessa, Kharkov and throughout Ukraine at 130.com.ua.
Heated Cape
What are recessed seat heaters
This type of heating involves the use of electric heating elements that are installed inside the car seats. Usually, it comes with two pillows, one of which is installed in the chair, and the second is mounted in the back of the chair.
In order to install this type of heating in a chair, you need to remove the chair itself and remove its upholstery. This can be done in any workshop, or you can try to install the built-in heated seats yourself if you have any basic knowledge related to automotive wiring.
One of the indisputable advantages is that such heating starts immediately after the ignition is turned on, and the heating process itself takes a minimum amount of time. This means that the car owner absolutely does not have to freeze in the car and he can immediately enjoy the heat.
What are external seat heating
With regard to external heating, they can be divided into covers and capes. Capes are of two main types: incomplete heated capes and heated capes of the entire area of ​​the chair. The first type covers only the backless seat itself. The advantage of this type is that such heating is small and cheap. The second option heats the seat and backrest. Both types of capes, as a rule, are included in the cigarette lighter socket and throw them into another car is not difficult.
Covers, just like capes, are mobile, that is, they are also very easy to put on and remove. But, this kind of heating has one big advantage over the cape-it does not slide over the chair and does not cause discomfort while driving.
The main characteristic for choosing such a heating system is the presence of a heating controller. This useful feature allows you to select the desired temperature for a comfortable ride. Another useful feature of these devices is automatic shutdown. Having such a function can save you from overheating or even roasting clothes.
Seat Heaters and Safety
- Using such devices significantly reduces the risk of or exacerbation of diseases associated with hypothermia;
- It has a therapeutic effect in intercostal neuralgia, pains in radiculitis, sprains, arthrosis;
- To start driving at temperatures below zero, it does not require a long warming up of the car’s interior, the seat heating time is two minutes.
TOP 3 heated seats
Best seat heating in car
Looking for a quality and the best heated seats in the car? This rating of heated seats in the car is made on the basis of such parameters as: high demand with positive feedback from our customers, high-quality manufacturing — absence of factory defects and service calls, and official warranty and post warranty support in Ukraine.
Automotive seat heating Elegant Plus 100 574 with heating regulator
Features:
  • ★ Wearproof dense material
  • ★ Built-in thermostat
  • ★ Suitable for any car seat
Auto warming Milex Arctic Black
Features:
  • ★ There is a 3-mode heating regulator
  • ★ With wire heating element
  • ★ Heating type — heated cover
Built-in seat heater Mitsumi M-1-0
Features:
  • ★ set for 1 seat
  • ★ with two heating levels
  • ★ carbon fiber heating elements (mats)
Materials on the topic
Seat warmers: Best Sellers
