Why does the car battery fail? Troubleshooting
Constant temperature drops, infrequent use, short-term trips and a large age of the car are the reasons that can affect the starting power of the battery. Because of this, one day the engine will simply refuse to start. How can I prevent this problem from occurring? Each reason must be considered.
Temperature changes
Heat can damage the battery. This issue may not always be detected in a timely manner.
How to save battery
- If possible, do not park in the sun.
- Check the battery charge regularly. It is important that the voltage indicator is at least 12.5 V.
- Check the terminals periodically to avoid oxidation.
- Monitor the state of the generator.
If you plan to travel a long distance, make sure that the unit is not recharged. To avoid this, you can turn on the headlights or a maximum of devices for electricity consumption.
If you need to replace the battery, you better leave it to professionals. A battery pack is associated with almost every device in the car. If you break the electrical circuit between the battery and the system, information in the control box and other systems can be lost. Various electronic components such as radio may need to be reprogrammed.
Irregular use
Some drivers believe that if you turn off the engine, no electricity will be lost. But some systems work even when the engine is off. This applies to alarms, locks, navigation and keyless entry. They use electricity even when the car is parked. Therefore, if the vehicle is idle for a long time in the garage, the machine may not rise. Most often, such problems occur if the battery is already old or it is cold outside (indoors).
How to solve the problem
If you haven't used the car for a long time, you need to check and charge the battery. If the battery is already old, replace it. Driving for at least 40 minutes a week can help you avoid starting problems.
Short trips
If you drive only when you need to go to work or to the store, that is, drive short distances, the battery is not able to recharge in full. Even a good and new battery can quickly fail under these circumstances.
Try to make long trips every 30 days. This way you can charge the battery through the generator.
Vehicle age
The older the vehicle (and battery), the higher the risk of sulfation and corrosion. This reduces the power of the device.
How to avoid
Check your battery regularly to make sure it has charge and is working properly.
Is it possible to save money on the purchase
You should choose a model that is able to cover the energy requirements of the vehicle. You don't have to buy expensive devices if you have a cheap car. The potential of the device cannot be fully used, and besides, you will have to overpay if you can save money. Manufacturers understand this. A whole line of S4 batteries from Bosch has been released. These batteries are optimal for all brands. The brand has incorporated a number of benefits into its products, ensuring operational efficiency. And thanks to the Power Frame grid, it was possible to achieve better conductivity, maximum current flow, and additional protection against corrosion. Therefore, in vehicles that consume relatively little energy, Bosch S4 batteries will provide a long and reliable power supply.
If you have a premium car and it consumes a lot of electricity, the S4E range is your best bet. During their creation, the advanced Enhanced Flooded Battery technology was used. These batteries are designed for passenger cars using a start-stop system. Resistance to cyclic loads allows the engine to operate when the battery is using a huge amount of energy while stationary.
You can choose and buy a car battery at 130.com.ua with delivery in Kiev, Kharkov, Odessa and Ukarin.
Related Materials
Car batteries: Best Sellers
