Review of Parkcity DVR HD 900. Multifunction DVR
For some drivers, the head starts to ache from such a variety of electronics. The manufacturer tries to shove as many functions and features as possible into each device, which are not always so necessary. The task of the company Parkcity was the development of such a model of the DVR, which in one case would combine all the necessary functionality.
And they did it. The DVR HD 900 model features advanced features. At the same time it remains affordable at its price.
Design Features
The central unit is mounted on the staff mirror. The principle of installation is very simple: you can do it yourself without spending a lot of time. It is fixed using rubber staples. The same mirror is protected from possible scratches and damages due to the presence of seals.
This method is convenient because the DVR will not limit the review to the driver.
The design is reliably hidden from the curious eyes of intruders, so you can safely leave it even for a long time.
The camera is on the left: it is compact in size, so it's almost impossible to notice it to a stranger. It can be rotated and thus select the optimal shooting angle.
All connectors are located on top: USB for power, memory card slot, external camera connection, connector. GPS-module has an external arrangement: it is optimal to install in the corner of the glass. The unit itself is installed on a 3M tape.
The picture is viewed on a 6.68-inch display with an IPS matrix. We get a clear image with all the details. You can turn off the screen while driving, and the recording will continue. The system is controlled only through the sensor, the manufacturer has removed all the mechanical buttons to save space.
Another useful feature is the presence of an additional external block. So, you can shoot even what is behind the car.
System interface
Parkcity DVR HD 900 runs on Android OS. For many users it is already familiar, since it is used on smartphones and tablets, so in principle there should be no problems with management.
At your disposal are 1000 applications in the Play Store. You can download both entertainment and navigation programs. The DVR is equipped with a wireless Wi-Fi network, as well as a 3G module. With the help of the Internet you can download programs and check information about traffic jams, use maps. Thanks to the presence of a Bluetooth module, you can talk on your smartphone using a speakerphone.
Among the pre-installed applications there is Yandex navigation, where besides the map there is information about various objects and installed cameras on the road.
Buy Parkcity DVR HD 900 in Kiev, Kharkov, Odessa you can on 130.com.ua delivery in Ukraine.
The result
Video Recorder Parkcity DVR HD 900 solves several problems at once, due to what becomes one of the best in its price category. Undoubted advantages include the Android OS, dual-channel recording, touch control, and the availability of wireless networks.
Video recorders: Best Sellers
