View of the video editor Gazer F117
Gazer F117 - budget model from a well-known manufacturer. So, in a standard complete set all necessary elements are provided, that you can use the device right after purchase. For its low cost offers even better features than models more expensive. Let's consider its features and determine if there are drawbacks.
Overview of the DVR Gazer F117
Design of the DVR
The design is light and compact, the parameters are 99x49x37 mm, and the weight is only 72 g. On the front side there is a main mechanism: a camera with 6 lenses. The back of the case is equipped with a display with a diagonal of 2.7 inches. Convenient location of all necessary inputs / outputs: microSDHC - at the bottom, HDMI - left, on / off and microphone - on top.
A useful feature - the manufacturer equips the screen with indicators for more convenient control of the microphone, motion sensors.
In the menu, you can adjust the sensitivity of the G-sensor. Other useful features:
  • Timer - you can set the display to turn on or off automatically or the DVR.
  • In the settings you can add to the record "titles", for example, your car number.
  • Hot keys help you to change the settings on the road without being distracted from the road.
  • With the backlight of the keys, you can comfortably operate the device even in the absence of lighting.
For those drivers who are more comfortable with mounting the DVR to the front panel, manufacturers have come up with a useful opportunity - a 180-degree turn.
Mounting Gazer F117
You can install DVR in several ways: suction cup or tape. The latter option is more comfortable, since the fastening of the device is easier, and the design itself turns out to be more compact. However, after removing the Gazer F117, it will not be possible to fix it back to the same scotch. Therefore, choose this mount, if in the near future do not plan to shoot the DVR.
Buy a DVR in Kiev, Kharkov, Odessa it is possible on 130.com.ua with delivery across Ukraine.
Vaccum version is more practical, because you can always remove the device. One of the advantages - the presence of a hinge: you can rotate the body. The power supply is provided with a bracket.
The quality of shooting Gazer F117
A clear video is obtained due to the presence of 6 lenses, a viewing angle of 140 degrees and WDR. The aperture is F2.0 - the camera captures more light, so shooting is of high quality even in low light conditions.
The only drawback - at night we still get not so perfect clarity. So first go to the settings and check all the parameters so that they are configured for Full HD.
The model shows its abilities well in conditions of sharp light fluctuations. Even if the object turned out to be highly exposed, the video looks clear, because WDR technology is used.
DVR allows you to increase the security system of cars, thanks to the presence of a motion sensor. So, the system goes into the standby mode to save the charge, and when the sensor triggers, it starts recording. You can adjust the sensitivity of the sensor yourself.
A useful feature - all videos that are recorded during a sharp braking, turning or impact, will be protected from cyclic rewriting. And all thanks to the presence of the G-sensor, which can also be adjusted depending on the conditions of the trip. So, the device works continuously, and important videos will be saved in the system.
The result
Gazer F117 for its budget price offers impressive features and pretty good quality. At the same time, it is very compact: it will fit in your pocket. It turns on in automatic mode. In this price category, this model is by right one of the best.
Product from review
Video recorders: Best Sellers
