Overview car component speakers Kenwood KFC-PS704P
Acoustics Kenwood quite popular among motorists because it perfectly combines the high quality and affordable price. Their dynamics demonstrate balanced sound and are suitable for installation in all cars, as they have usually standard dimensions, suitable for installation in regular places available. In this article we will look at component speakers Kenwood KFC-PS704P and will talk about its features and benefits.
Overview of component car speakers Kenwood KFC-PS704P
Design features
Acoustic kit Kenwood KFC-PS704P includes midbass (woofer/midrange) tweeter (tweeter) and crossover. This is enough to provide excellent sound transmission and make the sound of music inside the car a complete and well-balanced.
At first glance, the bass/midrange speaker nothing special design, this is the usual dynamics, except that the flange of the basket was an unusual relief. But this is a very important feature that solves several problems. This design feature enhances the rigidity of the basket. With conventional "flat" flange during installation can sometimes much drag that causes skewing extruded basket. The second feature with that bundled with speakers are a special adapter rings that allow you to set the perfect acoustics in the regular places. Speaker size (with mounting "ears") corresponds to 165 mm.
The speakers got polypropylene cones, they are light and high rigidity, which is different from the acoustic cheaper options. Such a diffuser-one of the important factors of good sound. The coil has a size of 1 inch. It is also worth noting the excellent ventilated magnet system.
Tweeters have quite a standard size, the fabric is quite soft dome, its diameter is 25 mm. Non-removable grid. Neodymium magnet. Housing is not huge, but the installation depth they still get rather big, especially when you consider sticking with the "home front" mounting studs.
To connect the speaker wire terminals are used with a double set of terminals. This greatly increases the ease of connecting tweeters, which are often installed near the midbass, for example, in car doors. Note that with the installation of the right does not even trained person, as to confuse inputs and outputs is difficult, almost impossible, because the terminals vary in size. Also worth noting is the presence of a set of special "spiders" that make the installation of the tweeter in a regular place as simple and convenient.
At the same time the tweeter there is another important feature-you can change the angle of the feed direction of sound, it can be useful if the speakers have a clear direction, the angle adjustment after installation makes it easy to adjust their position
Standard and familiar to all individual crossovers in the complete automotive acoustics there. Midbass is operating at full bandwidth, but for the tweeter is a special second-order filter is combined with a wire, which serves as a crossover.
Sound Features
As for the sound, then for its price range, this model shows a very good performance. Acoustics is different even tonal balance. The sound of a smooth, well-balanced. Speakers work in the frequency range from 63 to 24,000 Hz.
The sound at medium and low frequencies
The low frequency potential of this car audio is very good. The lower bass is slightly inferior, but it is well compensated by certain sound frequencies to the middle and upper bass. By its nature, bass performance is very neat, no extra emphasis pancha or blurring sound.
As for the mid-range reproduction, the data show the dynamics of the smooth sound, somewhat reminiscent of how sound the classic model with paper cone speakers. Despite the very affordable price, there is no sharp cries, noise and dirt. And vocal and instrumental music sounds natural and unobtrusive. Frank no dips in the midrange all at a very good level.
The sound at high frequencies
At higher frequencies the sound is clear and easy. Of course, audifily you may notice some sound simple, but the acoustics in this price category, all practically perfect. Tweeter excels with its role and no problems playing music in various genres, pop, instrumental, electronic, and more.
Pay attention to the correct installation of tweeters. This is important in order to achieve high quality sound transmission. If you send them to the forehead, then the sound will be distorted greatly, but there may be some oversupply treble. Some people like it, but still the best option to install tweeters in the rack with a small U-turn, for example, send them to the opposite side window. Of course, you yourself can experiment and find for themselves the best option that is right for you.
Summing up
In general, car speakers Kenwood KFC-PS704P very worthy behaves. Despite the simple, at first glance, the design, it has been successful, as the creators managed to balance everything, providing excellent performance.
The sound quality does not cause serious complaints, the speakers sound easy, sound is flat, does not tire the listener. The filter is well coordinated and aligns characteristics tweeters, so you can set the speakers and everything is ready to go, no major adjustments and upgrades here is not necessary. That is, you do not have to bother with filters per channel for connecting. Tweeters be connected via standard crossover filter to a pair of channels, and the main speakers-to another. In the end, you get the best per-channel connection and the ability to adjust the delay independently for the midbass and tweeter. Problems with the installation is also no, as already mentioned, the bundle includes everything needed for installation of acoustics.
There were no significant deficiencies in this kit component acoustics there. It may be noted perhaps that is not the smallest planting depth tweeters. However, serious problems it causes.
If you want to get a good sound in the car at a reasonable price, our online store 130.com.ua offers to buy speakers Kenwood KFC-PS704P in Kiev, Odessa and Kharkov with delivery across Ukraine. You can also pick up and other accessories and acoustic equipment for your car.
Materials
Car acoustics: Best Sellers
