Overview of the car stereo Kenwood DMX8020DABS
Kenwood DMX8020DABS - a new radio, which replaced the DMX8019DABS receiver, which last year received the prestigious EISA Awards in the category "Best Car Head Unit 2019-2020." The novelty is not inferior to its predecessor, titled and provides maximum functionality.
Features Kenwood DMX8020DABS
In this digital radio is the automotive manufacturer has provided ample opportunities not only your music, but also for viewing video files in high quality. That is, its installation in the cabin will provide a true multimedia center, which provides the user with access to all the most modern services and online resources. Let's take a closer look at all of its features and capabilities.
Large touch screen
Radio Kenwood DMX8020DABS equipped with modern capacitive display with a diagonal of 7-inch. He received additional anti-reflective coating made with the use of Anti-Fingerprint technology, Anti-Reflection and Anti-Glare. image resolution is 1280 x 720 (HD 720P). This allows you to watch your favorite movies and video in very good quality.
It is also worth noting that there is a possibility of adjusting the brightness, contrast, color and other parameters when installing an angle. This, as well as the use of Viewing Angle technology ensures that the picture in all conditions will remain as natural, there is no distortion.
Support for many formats
The device works perfectly with all major audio file formats: MP3, WMA, AAC, and FLAC and WAV. While maintaining High Resolution Audio technology which ensures high quality reproduction up to 192 kHz/24bit.
As for video formats, this media station can easily cope with the reading of the majority of standard files MPEG1, MPEG2, MPEG4, WMV, H.264 and MKV.
Wireless data transmission technology Bluetooth
Thanks to the built-in Bluetooth version 5.0 to the car stereo can be connected simultaneously to two mobile phones in hands free mode, ie they can be used to make calls while driving and not be distracted from driving. In addition, BT Audio mode, listen to streaming audio, the system is capable of supporting simultaneous connection of up to five smartphones.
Also, separately it should be noted that the implementation of the modern technology audiostriminga file encryption (Advanced Audio Codec), thereby able to improve the quality of the transmitted signal.
Have all the necessary connectors to work
Kenwood DMX8020DABS has a plurality of connectors for connecting external equipment, such as:
- two USB-ports, which can be connected not only to smartphones and flash drives, but portable SSD and HDD large volume formatted in NTFS.
- HDMI-input, which can be used to connect the DVR or expand the multimedia system with additional sources - from the media player to a game console.
- The connections for the three video cameras.
multimedia capabilities
The head unit supports the Apple CarPlay and Android Auto technology that facilitates the use of radio in conjunction with smartphones, as well as significantly expanding the multimedia capabilities of the radio, as the driver in the car is able to use modern digital assistant - Siri Eyes Free and Google Assistant
The company KENWOOD one of the first in the world began to produce car radio with support for Wireless CarPlay and Wireless Mirroring technologies. These technologies allow to display on the monitor of the head unit that is currently displayed on the device's screen, and control the mobile device directly to the head unit.
Sound
The Kenwood DMX8020DABS has a very good and high-quality sound thanks to the fact that the device has received power MOSFET amplifier 40x50 watts. In addition, there is a built-in DSP sound processor, which allows very flexible sound settings using the 13-band graphic equalizer to control sound delays, and adjust the volume by channel. High quality and speed of signal processing provides the chip AK7738 from Asahi Kasei.
Sound settings here quite a lot, so it is very easy to choose the best to meet the requirements of almost any listener, among the most important and interesting features are the following:
- adjustable tweeter broadband channels - available in the normal connection mode, not per channel. It's kind of shelf-filter, it can be used to lightly dampen the level of the high frequency signal.
- adjustment filter slope to 24 dB/octave in the three-lane mode for all channels.
- 13-band equalizer - has a very simple and convenient graphic design, a feature that curves can be set simultaneously for all audio sources, as well as individually, for each individual.
- Display of the delays at the same time shows how the physical distance to the specific dynamics and delay from the most distant.
- A convenient volume control for a variety of sources - the user can set the levels for all speakers at the same time or for a current .
Another very useful and convenient functions of the multimedia complex is the ability to build and configure two separate zones. That is, for passengers in the front and rear seats can be switched to different sources of sound, creating optimum conditions for listening to music in high quality. Just note that this option is only available in normal, not a per-channel mode.
Easy management and configuration
The first time the user has access to the basic settings. It is possible to choose the color illumination mode in the rear chamber, and adjust the viewing angle of the screen, this allows correct color gamut of a display picture on the monitor, taking into account the angular characteristics of the liquid crystal matrix.
The sensor is quite sensitive, quick to respond to touch, when executing no brakes. Therefore, management turns easy and as comfortable as possible.
The external design of the standard menu, it was very similar to what has previously been in other models Kenwood. Separately want to note the use of the screen with widgets. It represents yet another version of the "home" screen, where each user can deduce for themselves the right information. At the bottom of the menu, you can also adjust and change for themselves and function blocks, leaving those which will be used as often as possible, to have everything at hand.
All very carefully thought out and done so that the user was convenient to regulate and control all functions of the device. Prior to each function, you can access only a couple of clicks. For example, there is even the possibility of calling the adjustment menu is not using the on-screen buttons, and using a special physical button on the service of sub "ledge". The menu will appear at the top of the screen.
Summing up
After evaluating all possible multimedia station Kenwood DMX8020DABS, it can be argued that this is a modern and multi-functional model where the producer was able to combine high sound quality and the most advanced digital technology. Installation of such radio will turn your car into a true stereo system, which allows you to enjoy your favorite tracks in the highest quality, as well as provide an easy and seamless integration of basic functions on your phone. The system shows great potential, there is all that is necessary to the modern driver, nothing more.
Kenwood DMX8020DABS - this is the best choice if your goal is to get the perfect sound and do not want to spend money to buy a separate sound processor. This is a very high-quality and well-balanced unit with many useful functions in the road.
Buy radio Kenwood DMX8020DABS in Kiev, Kharkov and Odessa, you can always online store 130.com.ua.
Related materials
Car stereos: Best Sellers
