When to change the oil?
Engine oil is largely responsible for the normal functioning of the engine. It regulates the operation of all moving parts of the device, absorbs heat, retains moisture. The engine oil, together with the coolant and brake fluid, as well as transmission oils, allow you to safely use the car. However, the fluid must be gradually changed, because their stock is not unlimited. So, drivers have a question when to change the oil, because this process depends on many factors.
When to change the engine oil?
In the service book of each car shows the approximate timing of oil change, but there are still certain nuances that need to be considered. Fluid quality deteriorates if the engine is subjected to excessive loads. If you keep driving smoothly, then the engine is running normally and the oil gets polluted more slowly.
Traveling in a big city, when you need to constantly stand in traffic jams, drive through unpaved surfaces, belong to the type of excessive loads. Therefore, the driver must periodically check the oil for its timely replacement. So, you need to do this procedure with a probe: black oil-a signal of the need for urgent replacement.
We should not expect a run of 12 thousand km, because this value is average, but not individual for each car. If you have a diesel engine, then this parameter is reduced to 8 thousand km, because the work of this design is much more difficult. Even if you have not yet reached such values in the run, you will still change the oil if necessary.
When to change the oil in the box?
Mechanical and automatic transmissions use special gear oils. As a rule, such liquids are synthetics with the addition of special additives. Consider the features of each device:
Mechanical gearbox: gears heat the fluid to 150 degrees, and in the contact patch this parameter can be twice as large. In such conditions, the oil begins to boil and foam, losing its properties.
Automatic transmissions: here the fluid performs another function-it transmits torque to the gears. Sometimes even special cooling systems are not effective.
It is recommended to change such oils after a run of 50 thousand km, but in cars with rear wheel drive it is possible even after 60 thousand km, since they have a much smaller load. These are average values; if necessary, you can change the oil even after 10 thousand km. you can buy motor oil with delivery to Kiev, Odessa, Kharkov and throughout Ukraine on 130.com.ua.
When to change the oil in the bridge?
If your car is rear-wheel drive, then you can change the oil in the bridge even twice a year, but taking into account individual operating conditions. If you have a front-wheel drive car, you can check the condition of the oil at a technical inspection.
Materials on the topic
