How does heat affect the condition of the car?
Hot weather, hot roads, long trips and dry air have an extremely adverse effect on the operation of auto components. In this material will tell you about the main factors affecting changes in machine operation in the summer and learn how how to protect parts from excessive heating, and interior with a body & nbsp;-from burnout.
Engine loses performance
Due to extreme heat, less concentrated oxygen enters the engine and this can lead to a deterioration in its performance, since it needs to work twice as much to generate the usual amount of power. As a result, the engine runs at the limit, overheats and loses power.
In the summer, you need to more carefully monitor engine lubrication and change engine oil on time. Do not forget about the coolant and fans, which save the motor from overheating, maintaining the optimum temperature.
Coolant evaporates
What we call "antifreeze" in during the winter, in during the summer is defined as "coolant". Low coolant levels can literally kill the engine. Worn hoses or a damaged radiator can result in coolant leakage and engine temperature rise. During the summer months, keep a close eye on your vehicle's temperature sensor to avoid overheating.
Evaporation of service fluids
Oil and coolant are not the only fluids you need to check to help your vehicle perform at peak efficiency during summer. Transmission fluid and power steering fluid should also be checked regularly to ensure that these systems are working properly. Plus, believe it or not, fuel literally evaporates from a hot car faster than a cold one-straight out of the tank. If possible, store your car in a garage or in shade parking lots-this can help prevent natural evaporation of liquids.
Rapid battery drain
Usually, car batteries are hard to tolerate frost. But hot weather affects the battery is less detrimental, and can significantly shorten battery life, because excessive loads contribute to premature battery wear. This is especially true if you reboot the electrical system with additional devices, while while the air conditioner is constantly running at full power. Therefore, additional vibration from long summer trips can also damage the battery. If you are doing regular maintenance on your vehicle, make sure a technician has properly checked and the battery, if necessary, topped up with the correct fluids.
The air conditioner starts to run slower
In the summer heat, air conditioning relieves us of discomfort and in the car, we can feel like in an autonomous state, while everyone else melts under the sun. While car air conditioners do their job well, too much heat outside the car can make it run for twice as long, just to cool the interior. As a result, a constantly operating air conditioner can overload the car's engine, and again but & nbsp;-take some of its power, which should have been used to maintain the characteristics of the car in perfect shape. Maintaining and replacing the cabin air filter can improve cooling and extend the life of the air conditioning system.
Negative effects of sunlight on plastic and rubber parts
Plastic and rubber are the most malleable materials that can be damaged due to too high temperatures and the sun. Even the wiper blades can melt on the windshield when heated. And while rubber tends to become more elastic and to loosen, plastic in the sun becomes hard and brittle.
Car interior burns out
The upholstery and seats are very susceptible to damage under the sun, auto textiles tarnish over the years, and leather seats crack and climb. The best way to prevent this is to avoid direct sunlight. As a solution & nbsp;-install sun blinds or buy a car awning that will 100% help protect the car from scorching rays and make the interior a little cooler on hot sunny days.
The pressure in tires is decreasing
The effect here is almost the same as in the case of plastic, but in this case your safety is at risk, as there is a danger even at low speeds. Hot tires on hot asphalt are no longer only a common cause of increased stopping distances, but and a sure way to get quick wear when driving and abrupt stops. If, at the same time, the tires are incorrectly inflated & nbsp;-the risk of failure is even greater. Checking the pressure in tires is one of the most important things that you always check on throughout the year, but and especially often & nbsp;-in the summer months.
Cracks appear on tires
One of the fastest reasons for ejection of rubber is the appearance of cracks on the tires. Rubber, being for a long time under the scorching sun, deteriorates much faster, while the sidewalls especially suffer, cracked due to excessive ultraviolet radiation and heat. Prevent dangerous situations by checking your tires once every month and replacing them before they become worn out.
Car paint cracks becomes dull
Car paintwork is constantly attacked by various threats. Dust, dirt, loose stones, insects and especially solar ultraviolet light. All these factors not only can cause heartache for the car owner, but and significantly reduce the car resale value. With the paint of the car over time from the sun, the following happens & nbsp;-first, the paintwork begins to fade, and then crack and peel off in a strange way.
This is a list of only the most popular car problems that can be associated with heat and sun. In fact, the list can be supplemented with other troubles, in any case, every car owner himself must understand when it is required for his car to cool down. Stay vigilant and keep an eye on vehicle maintenance and you will surely enjoy a carefree summer.
Related Materials
