How to choose a good subwoofer in the car
A special desire to buy a subwoofer arises from those drivers who have already installed a good radio tape recorder and acoustics, made noise isolation, and did not receive high-quality sound. Today we offer a wide range of these products, each model is different in type and functionality. Therefore, before buying it is important to determine all the nuances.
Which is better: active or passive subwoofer
The difference between passive and active devices in their design. Consider each type in more detail.
Active Subwoofer
These devices have a built-in amplifier and do not provide external sound settings. Due to the balanced design, subwoofers have high reliability. If this parameter is your priority, then you can choose active devices without a doubt.
There are drawbacks. For example, it may be difficult to install, since such models are sold already assembled. If you compare the sound, then it is better for passive subwoofers. The reason-inexpensive materials for the production of housing.
Passive Subwoofer
This type of device does not provide an amplifier, so you will need to buy it separately. And often, you will need to replace the speaker cables with better ones.
If you do not understand the systems yourself, then it is better to entrust the installation to a specialist who can correctly install the entire audio set. Additionally, you can customize the sound in the amplifier.
Which is better: open or closed subwoofers
By their design features, car subwoofers are open and closed. Consider each one of them.
Open subwoofer
This is a powerful speaker that fits into any cabin panel. There is one drawback-such models are suitable only for an amateur, but not for a connoisseur of high-quality bass. You can adjust the sound only with the help of special filters.
But the advantage of open subwoofers in their affordable price. Ideal for ordinary listeners who do not put high demands on the sound.
Body Subwoofers
By design, these types of devices are much more complicated. The speakers are placed in a special case. There is an opportunity to make an individual order of the subwoofer, taking into account the features of your cabin.
Case subwoofers for cars are of the following types:
- A phase inverter is a closed case with a special tunnel that improves the sound of the speaker. There is no interference in the frequency range of 50-120 Hz. It has good performance and is protected from any damage.
- Closed case-despite the simplicity of the design, drivers rarely use it. Such designs produce lower frequencies and have a minimal risk of mechanical damage. A major drawback is poor performance.
- Bandpass-it has a large size and is characterized by high performance, good sound even at a frequency of 20 Hz, provides for location anywhere in the car.
So, it all depends on your goals. If you just want to improve the sound, then the budget, the usual model is enough for you. For those who put high demands on the sound, you will have to choose a more powerful device. You can buy a subwoofer in Kharkov, Odessa, Kiev with delivery in Ukraine on 130.com.ua.
Watch car subwoofer video reviews
Materials on the topic:
Car subwoofers: Best Sellers
