Intelligent battery chargers for car batteries
Prehistoric chargers can not boast of high efficiency, and this is proved by their unstable supply of current. The algorithm of their work is only available to garage shamans of the middle of the last century. The cars are getting smarter and the devices for charging the batteries are not falling behind them. And today, 20-kilogram designs have been replaced by smart devices, which, one might say, are one of the most sophisticated tools for servicing batteries.
The modern design is a small device that works with an intelligent algorithm and is controlled by the microprocessor's operation count. Advantages of such models:
- Battery maintenance is as economical as possible.
- Depending on the degree of deterioration of the battery itself, its service life can be extended.
- Intellectual memory can restore the battery.
- The whole process is automated.
- Stable current supply.
And most importantly - they do not require any knowledge in charge cycles, accurate measurements and other. You only need to know the capacity of the battery to properly pick up the memory.
Features of work
Standard impulse chargers are charged first to the minimum parameter, after which the main cycle begins. The duration may be even a few days, and it is necessary to periodically check that there are no problems. Intellectual models work differently.
The main charge cycle lasts 5 hours, and further - finishes charging to the required parameters and characteristics. In whole, the duration of the whole cycle is up to 8 hours. But the exact time depends on the battery condition and its capacity. In addition, such devices offer several modes of operation:
- Restore the capacity even on the oldest batteries.
- Test work to determine what exactly is needed for the functioning of a certain battery, for example, smooth charging or with impulse current.
- Smooth start - maximum voltage will be 12 V.
- Desulphation to bring a battery into the building, which has been idle for a long time.
ИIntellectual chargers are suitable for any battery, even for helium or calcium. And, for account of the absence of a coil, the design weighs up to 2 kg. The cost depends on the capacity of the battery for which it is intended, and the availability of additional functions.
Buy a car battery charger can be delivered to Kiev, Odessa, Kharkov and throughout Ukraine at 130.com.ua.
See video reviews of chargers
Starter-chargers: Best Sellers
