How to choose a GPS tracker
GPS trackers and other devices responsible for monitoring vehicles are currently among the most common in the world. Until recently, GPS trackers used only logistic services to control commercial transport, but now the tracker can afford each one. After all, the GPS tracker will not only allow you to monitor your transport on your own, but also, in the event of theft, track the attacker's movements.
Personal GPS tracker will be useful for: monitoring children, the elderly, company field workers, animals, tracking valuable cargo, outdoor activities and tourism. Looking for a GPS tracker? Buy in Kiev, Odessa, Kharkov, you can at 130.com.ua. Delivery in Ukraine.
When choosing a GPS tracker, you should pay attention to the presence of a built-in battery and battery life, the ability to monitor vehicle movement online, the number of SIM cards and the presence of additional inputs for connecting fuel control sensors, turning on/off the ignition and others.
Online object tracking
To select a GPS tracker based on the ability to track the object in real time, click on the corresponding image.
Tracking Type
Online tracking
With this feature, you can monitor the movement of the vehicle in real time, through special monitoring services.
Offline tracking
With the help of trackers without the possibility of online tracking, you can track the location of a vehicle. Such trackers are in sleep mode most of the time and after a certain period of time they send SMS messages with the coordinates to the owner. You can also manually submit a request to the tracker to obtain the coordinates of the car.
Built-in Battery
To select a GPS tracker based on the built-in battery, click on the appropriate image.
Built-in battery
GPS trackers with built-in battery are capable of autonomous operation for a long time, without the need to connect to the vehicle’s on-board network. Some models can work up to 3 years on one battery charge.
Number of SIMs
To select a GPS tracker based on the number of connected SIM cards, click on the corresponding image.
Why a SIM card tracker?
GPS trackers transmit information about the location of the vehicle through the GSM channel. For this purpose, a SIM card of any mobile operator is installed in the tracker. It is recommended to install a SIM-card of a similar operator that you use for mobile communication. GPS trackers with two SIM cards are more reliable, because if the connection of one operator disappears, the second SIM card will work and in any case it will be possible to get auto coordinators.
Auxiliary Inputs and Outputs
To select a GPS tracker based on the availability of additional inputs and outputs, click on the corresponding image.
Why does the tracker need additional outputs/inputs?
Various additional sensors can be connected to the tracker with additional inputs, such as:
- - ignition on/off sensor;
 - - lift sensor;
 - - SOS button;
 - - fuel control sensor.
Materials on the topic
GPS trackers: Best Sellers
