Automotive Articles - GPS Trackers
GPS-tracker allows you to monitor your car with a satellite. Such devices are actively used by various transport companies, vehicle fleets, security services, etc. In normal life, this element can be useful for improving the level of transport safety or in cases where one car is used by several people. For example, if someone from the family went on a trip and does not pick up the phone to make sure everything is good, you can track the car's movement.
The main components of any model are a satellite and a modem. The first element is necessary to receive a signal about the object's movement, the second one is necessary for transmitting this signal. The choice of GPS-trackers depends on the desired type: it can be a device with a built-in power supply or universal, which can be connected to the network.
One of the main requirements for such designs is a long work. For example, if your car is stolen, you will be able to track its location for a long time. GPS Trackers has these advantages:
Do not submit a false call. For example, some models of alarms are triggered, even if the cat gets into the hood.
Unlimited range, thanks to the operation on the basis of the satellite system.
It is almost impossible to hack, because they reliably hide from the eyes of the hijackers.
The question of how to choose GPS trackers remains open always. So, during the purchase it is recommended to consider the following parameters:
Battery capacity. Provide an indicator that would allow the device to be charged in a timely manner.
Mounting methods: magnets, bolts, without fasteners. It all depends on the type of object and the operating conditions.
Tightness: high resistance to moisture and dust, if you plan an external location of the GPS tracker. For example, on a bumper or wheel arches.
A way to activate and retrieve information: it can be an application, a message, a site.
Accuracy of provided data: the permissible error should not exceed 2.5 meters.
It is desirable to choose a model with the possibility of further expansion of the functional. After all, in the future you may want to have additional sensors.
