Buy a GPS tracker and watch every step!
Surely each of you at least once saw a scene in a film when a security agent attaches a bug to a criminal's car, and then calmly watches his movements while sitting at a computer. In order to feel like a spy, a simple device called a GPS tracker is now enough. With this little box in your hands, you can really get involved with the agents of the special services. :)
So how does this little black box work? GSM/GPRS/GPS tracker contains a GPS module that allows you to receive your coordinates from satellites and a GSM/GPRS modem, which in turn, transmits location information with coordinates to the monitoring system server via GSM/GPRS channel or using SMS messaging. Thus, a person who has a personal GPS tracker will always know the location of the object being monitored and all his movements. In short, it is an excellent monitoring system that allows you to track vehicles and any other object, and if necessary even listen to the tracker’s surroundings by calling it from a mobile phone.
As an example, I would like to consider the GPS tracker (logger) Xexun TK-103 is a compact, fairly inexpensive device, but with good functionality. Looking for a GPS tracker? Buy in Kiev, Odessa, Kharkov, you can at 130.com.ua. Delivery in Ukraine.
From the very beginning, you should note the simplicity of working with the GPS tracker-in order to make some settings, and also turn the device on or off, you just need to have a mobile phone. Setup is done by exchanging SMS commands with a GPS tracker.
The dimensions and weight of the tracker are pleasantly pleasing-this is a small box the size of a matchbox and weighs only about 100 grams. Complete with the TK-103 v3 tracker (logger) you will find a blocking relay, a GPS antenna, a GSM antenna, wiring, software and instructions. Also, for a GPS tracker, you need to buy a SIM card-when buying, try to choose a tariff plan with cheap Internet traffic and good GSM-coverage of the operator.
The algorithm for setting up the tracker is quite simple-just send a message from the mobile phone with the command for the tracker and a password, with the result that you will receive a response. There are three possible answers:
- message OK;
- ERROR message;
- the absence of any signals from the tracker (you shouldn’t worry, it doesn’t mean that the command is not executed).
The GPS tracker Xexun TK 103 v2 has two modes of information transfer: either sending SMS messages to trusted numbers, or data transmission using GPRS. By default, the tracker sends call data to a SIM card that is inserted into it before use, but if necessary, you can set up automatic sending of location information after a specified period of time.
In the event that there is no GPRS signal, the data will automatically be stored on the SD memory card-this feature is also provided in the GPS tracker Xexun TK 103 v2.
GPS trackers TK-102 and TK-103 are fully integrated with free site monitoring services.
For example, on the free service car-online.ru you can track all the movements of your car right on the map. Another feature of the GPS tracker Xexun TK-103 v2 is that it supports two GSM Sim cards-this is a kind of reassurance in case one card does not have a GSM signal. One Xexun TK-102 GPS tracker battery lasts for two days, and the Xexun TK-103 GPS tracker connects directly to the vehicle’s network and contains a built-in battery.
GPS tracker (logger) Xexun TK-103 will guard your car’s safety, because as soon as the vehicle starts unauthorized traffic, an SMS message is sent to your mobile phone with a corresponding notification. What to do next? You simply send an SMS message to the GPS tracker to stop the vehicle engine and the kidnapper remains out of work.
A little about the technical characteristics and stuffing device TK-103
Content |
Specifications |
Size |
80 (L) X60 (W) X25 (H) mm |
Weight |
100g |
Network |
GSM/GPRS |
Range |
850/900/1800/1900 MHz |
GSM sensitivity |
less than 102 dBm |
GPS chipset |
SiRF III |
GPS sensitivity |
–159dBm |
GPS accuracy |
5m |
Cold/Hot TTFF |
35/2 s |
Car Charging |
12-24 V input, 5V output |
Battery |
3.7V DC-ion battery Li, 1100mA |
Battery Charge |
48 hours |
Operating Temperature |
–10 ° C to +65 ° C |
Storage Temperature |
–20 ° C to +70 ° C |
Relative air humidity |
5% to 95%, non-condensing |
Where and for what can a GPS/GSM tracker be used?
The most basic application of this device is found in the systems for controlling the movement of vehicles. Most transport companies have long concluded that it is easier and cheaper to buy GPS trackers (or GPS loggers) and put them on cars than to search for stolen vehicles. Also, after installing the GPS tracker on the vehicles of the fleet, the issue of the deviation of transport from the route is solved, when drivers drive in on business, spending their working time and fuel of the company.
It is also very convenient to control human movements using GPS trackers-in this case, devices such as the personal GPS tracker (logger) Xexun TK-102 v2 are used. They allow you to ensure the safety of young children, the elderly-with the help of the tracker you will always know where your relatives are at the moment.
Personal trackers will also help pet owners-if your four-legged friend periodically goes for a walk, then you do not need to worry about how far he has gone from home-the GPS tracker will provide you with information on all of his movements.
In any case, if you decide to to buy a GPS tracker , you can be sure that you will never regret purchase-the device can be useful in the most ordinary and unusual situations.
Materials on the topic
GPS trackers: Best Sellers
