Where to leave the car at night?
Owners of cars are concerned about the question of where to leave the car for the night, so that it is safe: in the parking lot, in the garage or in the yard? A survey was conducted among motorists about this topic, which resulted in the following results:
As you can see, the majority are forced to leave the car in the yard of their house, a significant part is the owners of the garage, the rest use the services of paid parking. Let's look at the features of each option: what are their advantages and what they have disadvantages.
Those who own their garage, calm at the expense of where to leave the car: in the evening you just need to drive the car to the site and can sleep peacefully. However, what should those who do not have a private garage do, but who also want to leave the car in a safe place without any problems? In modern conditions there is a mass of options, the only question is which of them is better.
When parking a car in the yard, in order to protect the car from possible precipitation and the negative influence of sunlight, it is worth using car awnings. These are the so-called body covers, which completely cover the car and protect it. car awning to buy in Kharkov, Kiev, Odessa with delivery in Ukraine can be on 130.com.ua.
Secure parking
The most common myth that exists among car owners-is that for the amount paid, they get the right to compensation in case of any problems. However, everything is not so simple and profitable for you: the maximum that can (we pay attention to “can”, because it is not obliged) to make a guard is to call the police. As practice shows, until they reach the car is already robbed, hijacked or damaged.
The advantage of parking over conditional parking near the house is the call to the police, which sometimes pushes thieves and burglars to commit a crime.
There are advantages in the winter, because parking lots care about the comfort of their customers (for which they actually pay money): they clear the roads, so entry and arrival is always free. You can also charge the battery, if it is provided for in certain parking conditions. Agree, such opportunities simplify the life of the driver.
Covered areas
The difference between this type of parking and parking is that your car is under the roof. This is a huge advantage in all seasons:
- in the summer-protection from the sun, heat, so the cabin does not heat up;
- in the winter-from the snow, you will not need to spend time on removing the snow from the car;
- always-protection from precipitation, because the machine will always be clean.
Often, on such sites installed ventilation system that prevents the appearance of condensation inside and outside the car. However, real professionals will not stop even in front of such obstacles, but, again, covered parking areas allow for improved security systems: an increase in the number of security guards, security cameras.
The safest sites are parking in cooperation with the state security service, because they have every right to even use physical force in the direction of intruders.
The only drawback is the cost of such services, but do not forget that the miser pays twice.
How does the microclimate zone in certain areas affect the state of the car?
If you have your own garage, then first of all take care of installing ventilation, with proper and high-quality installation. This is especially important if you leave the car daily. Moreover, this question is relevant in any season.
For example, if the ventilation system is poorly installed in the room, then it is much worse than if you left the car just outside. After the rain you leave the car in a closed garage, where there is no ventilation or it does not work well, then in the morning you will most likely have problems with charging. This is because moisture is deposited on the ignition system, air ducts, which leads to such problems.
If ventilation works well in your garage, then your car will dry out quickly even after rain. Now the owners of the heated premises can grin, however, again, with a bad ventilation system you can also run into problems. For example, if in the winter you drive a car out into the frost, then the windows will sweat and even frost up. Therefore, you will need to wait until the machine adapts to sudden temperature changes.
Underground parking or simply closed rooms are ideal because they are equipped with all the necessary systems, due to which condensation does not form on the main nodes of the car.
To summarize: if you use the car every day, then it is better to give preference to parking. For the best security, choose sites protected by the state security service. For the normal influence of environmental conditions, suitable gated parking lots or a garage with a good ventilation system.
Related Content:
