The effectiveness of sound insulation in the car. Pros and cons
Great quality car audio due to noise isolation
After the door insulation was done, the effect of improving the acoustics sound immediately appears. It is very simple to explain it, because the metal on almost any car is very thin and when the acoustics sound, it “puffs up”. Applying vibration insulation increases the rigidity of the car door, and thus improves the sound. Moreover, in order to get high-quality sound, it is not necessary to buy expensive acoustics. Even the cheapest coaxial speakers will sound unexpectedly pleasant sound. The only minus in noise insulation is overweight. After the work of “Shumkov” the weight of the door will be greater, but not critical. There are legends that, as some motorists, after soundproofing, the doors begin to sink and they have to look for a replacement for the hinges. Not that it was not true, but everything is relative. If you glue a 10-layer noise insulation, it will not give much effect, but the weight will increase quite significantly. In order to avoid this, it is necessary to find a middle ground, when the weight of the door will be normal and the insulation will be effective. You can buy noise insulation in Odessa, Kharkov and Kiev on 130.com.ua with delivery in Ukraine.
A lot-it doesn't mean better. It is necessary to look for the most optimal option, and not to chase pasting all the details, and even in several layers with different materials. There is no sense from this.
Elimination of engine noise due to noise insulation
As for the noise of the engine, Shumka copes with them very well. The main thing is the isolation of the space between the motor and the interior of the car, since this is where the main source of unnecessary noise is located. In some cars there are very large slots and after seeding with absorbers, the noise disappears.
Noise from the engine is heard not through the hood, but through the engine compartment. And if you isolate it, the sounds will decrease many times or will be absorbed so much that they will no longer be heard so clearly.
What gives a properly made insulation car interior?
While driving, you do not need to raise your voice during a conversation or turn on the music at full volume in order to silence unnecessary annoying sounds. If a person has a domestic car or some kind of inexpensive foreign car, then Shumka will increase the comfort in the cabin. Riding in such a car will be felt at the level of middle-class cars and above.
Any expert will say that after the soundproofing done, the extra noise in the car is reduced and the difference between the open and closed windows is clearly visible. When the window closes, there is a feeling of silence and comfort, as in a premium car segment.
How to make inexpensive noise insulation in a car?
Of course, everyone wants not to spend a lot of money and get high-quality sound insulation. And it is possible. If you correctly approach this process with your head and make noise isolation yourself, then you can do it inexpensively.
The first thing to do is calculate the materials correctly. From the materials needed: on one door sheet vibration isolation Silent Car Grand 2 and sound insulation Butyplast Gerlen I. For greater effect, you will also need Butyplast Antiskrip to glue the doors from squeaking.
If a little finance, you can make noise isolation gradually. For example, this month you can isolate the doors, next-the floor, and then the hood, trunk, etc. And already in the process you can notice the difference between what was and how it became.
Total. It is possible to make correct and high-quality sound insulation even with a limited budget. This process is not complicated, but rather laborious and time consuming. But the effect is worth it, as you can easily see for yourself by making noise insulation of the car.
Materials on the topic
Noise insulation: Best Sellers
