What is a generator (power station)
The generator is a compact power plant that operates by burning fuel in an internal combustion engine. All models differ in the type of fuel, size, power, type of electric current. Accordingly, each of them offers its own possibilities.
All devices are divided into the following categories: petrol, diesel, gas generators and digital. Let's consider features of each of them.
Diesel generators
The diesel power plant operates on a diesel engine. It is practical to use for the main or emergency power source. Such models are characterized by a longer service life and low noise. And if there is a strong noise, it is only a signal about the failure of the internal mechanism.
One of the main advantages is fuel economy, due to which they gained popularity as the main source of the network. For comparison: in diesel models, the fuel consumption for ⅓ is less than for gasoline ones.
Petrol generators
Gasoline designs differ in their compactness. Suitable for use in residential areas, because they are almost silent in operation due to the features of the gasoline engine. Used fuel of high-octane gasoline, so these generators also have a high level of environmental friendliness.
When choosing, it is necessary to focus on the power factor. We recommend to calculate the approximate indicator in advance, taking into account the number of electrical appliances that you want to connect. Multiply the resulting parameter by the starting current factor, which depends on the instruments used. Add 20% for the stock and get the final value.
From the correctness and regularity of maintenance, will depend on the service life of models. It is necessary to replace filters, consumables in time, check airborne connections, and the operability of protective systems.
Gas generators
Such devices operate due to the gasification of solid fuel. In simple words, all the chemical energy of a solid fuel is converted into chemical energy of a gas.
Devices can provide electricity to small country plots and whole houses. The power index varies in the range of 5-25 kW. Some models are completely automated. For example, if the fixed network is disconnected, the system automatically starts, and when the power is turned on, the device switches itself off. This is practical for commercial enterprises.
Digital Generators
Such models are more compact in size and weight. Due to what became popular at mass events, where it is necessary to quickly and easily transfer such a design. Digital generators are very reliable and stable in operation.
Often, the noise figure does not exceed 9 dB, which is especially important in the case of residential buildings. The level of emissions is minimized, due to which power plants can boast of environmental friendliness.
Generator buy you can go to 130.com.ua with delivery to Kharkov, Odessa, Kiev and Ukraine.
The choice of the generator depends on the conditions in which you will operate it. It is also important not to forget about power and compactness. If you consider all your wishes, then you can choose the most suitable power station for your needs.
Generators: Best Sellers
