What should I do if the dipped beam shines badly? Causes and Troubleshooting Tips
Good car light is not only a well-off appearance, but also one of the safety factors on the road. And the second concerns not only the driver, but also the road infrastructure, which can be damaged due to an accident. So, what to do if the low beam shines badly?
It seems that the problem is easier to solve. But sometimes it is difficult to determine the cause. Well, if the car owner is trying to deal with the issue and looking for ways to solve it. But if the problem is ignored, in the future it may lead to accidents. Do not forget, poor illumination-this means lack of information about the part of the road, especially if its quality leaves much to be desired.
The main causes of poor lighting:
Bad headlight adjustment. After prolonged use or after damage to the car body, the headlight may change the angle of view. And now the light will not fall on the road, respectively, the quality deteriorates.
Insufficient generator voltage. To make sure of this reason, check with the outgoing nominal luminous flux. Standard-from 13.5 V. If the voltage corresponds to the power of the generator, then continue to look for the cause.
The hit of external elements. Most often it is moisture or dust. When condensate or dust accumulates, they absorb the luminous flux and the headlamp shines not so brightly. The solution is to clean the glass surface.
Dirty headlight from the outside. For example, when in contact with dust or gravel. You can install a protective tint that will extend the life of the headlamp.
Disturbance of contact conductance and subsequent oxidation of the lamp. You can simply treat the surface with silicone grease. And if the contact moves away, then try replacing the damaged mechanism. If the connector itself is faulty, just install a new one.
We recommend not postponing the solution to such a problem. And it is better-spend from time to time inspection of the headlamp in time to eliminate any malfunctions.
Related Content:
