Pure and beautiful salon-conducting an independent de-diving
Detailing is considered one of the most optimal ways to care for your car. This is the correct and timely maintenance, protection and cleaning of all surfaces, especially the body paintwork. Carrying out this procedure helps to get a beautiful and well-groomed view of your vehicle.
The end of autumn and the beginning of winter is always accompanied by the presence of abundant amounts of dirt, gravel and sand, and in a short time, chemical reagents and salt will be added to them. Therefore, you need to "take care" of your car more carefully in order to avoid more pollution and deformations inside and outside the car. Consider some recommendations and tips with which you can save your car, even without using professional detailinga in specialized services.
Getting Started
In modern times, it’s easy and you can simply do all the necessary manipulations yourself to ensure proper care for the car. There are now a large number of different substances and devices for cleaning, washing and carrying out other work on different surfaces on the market for nursing products, such as paint and varnish, plastic, leather, metal, glass or velor. Using these tools you can quickly and qualitatively clean any coating, even if it is very dirty or has not been cleaned for a long time.
The delaysing process starts from the floor mats:
- Rubber mats clean very well with ordinary soap or shampoo, after which these products are washed away with water;
- Pile mats should be carefully rubbed with a harsh brush, and then work with a vacuum cleaner. The use of the brush is necessary because with its help the mud accumulations on the pile are destroyed. It will also enable faster and more efficient cleaning mats.
In the same way, you can clean the upholstery with a stiff brush, and after-with a vacuum cleaner.
The next step in cleaning the cabin is to blow all the cracks and the inaccessible areas under the seats on the floor, under the panel and, of course, the panel itself. This can be done with the help of a compressor device or with a vacuum cleaner having an “on blowing” option. Thus, it is possible to quickly and effectively clean all hard-to-reach places in the cabin from dust and mud accumulations.
Air ducts for heating and air conditioning systems also need to be purged. To do this, you can buy a spray with compressed air, in the case of the absence of a compressor at hand. Such manipulations are carried out with the air filter in the salon-you can clean it or replace this element with new.
After completing all the manipulations, you need to completely clean the cabin with a vacuum cleaner from blown dust piles and other dirt. If the seats are made of leather, then they it is better to wipe them with a special conditioner after cleaning.
A great choice of auto vacuum cleaners for various purposes is better to choose on trusted sites.&Nbsp;our catalog has devices for dry and wet cleaning, various models and brands. Everyone will be able to choose the best option for cleaning the interior of their vehicle. On 130.com.ua you can buy auto vacuum cleaners in Kiev, Kharkov, Odessa with delivery in Ukraine.
Exterior car cleaning
The next thing to do is clean the tires. There are a lot of means to perform this procedure, however, what is important, it is impossible to apply the means, in the basis of which there is an acid. These components can result in damage to the cast disk elements, washing away of the varnish or oxidation of the disk metal. In another case, stains on paint may occur if the body part of the car accidentally gets dirty.
Finished with the wheels, go to the body. Self-washing, without using a mini-wash, will provide an opportunity to assess the quality of the paintwork and detect possible irregularities or damage to the surface.
Very important! During body wash time, it is not advised to use conventional dishwashing detergents. Despite their excellent properties, which allow for a good degreasing of the surface, they also contribute to the washing off of a special protective wax coating, and also various additives that are found in special car shampoos. The result is the occurrence or increase in the number of corrosive foci on the body in places where scratches or chips have occurred.
After washing the body, you need to dry it and not leave it for self-drying. The reason for this is the presence of salt and dust in the water, which, after normal drying, remains noticeable. Moisture can be removed using a rubberized brush or on a silicone-based basis, after which you can wet the wet places with a microfiber cloth.
Polishing
Next is a body inspection. The paintwork should be clean, with a uniform and deep color. But, after a long use of the car due to a number of factors, it loses its original appearance. This is the impact of sand or dirt, bright scorching sun or bird droppings.
- To detect a problem, you must hold a clean and dry hand over the entire body of the car to feel its condition.
- If the surface is smooth and even, then you can’t worry, everything is fine with it.
- In another case, rough spots will be felt-in this situation you need to think carefully about restoring the coating and polishing.
Spots and other damage can be repaired in two ways:
- mechanical. This is done using special polishing equipment. They carry out polishing using the clay intended for it;
- chemical. For this purpose, special tools are used to help remove the flaws by carefully dissolving.
Sometimes polishing requires the use of these two methods, but their frequent use is extremely undesirable. The reason for this is the possibility of thinning the paint layer, and with frequent polishing, you can completely grind off it.
The quality of the work can be checked very simply: put the ruler in a perpendicular position and look at its reflection. The more numbers you can see, the better the work done.
After completing the polish, you need to go to the the next stage of detailing the exterior of the car, and it is the cover with a protective layer of the body part. Often used for this means, in the basis of which is wax. Some recommendations are important before applying the product:
- Distinguish between substances of liquid and solid consistency. Some masters use the first option, others-the second. The choice of means is not is fundamental, everyone chooses the one he likes to use;
- You cannot combine these two types of tools, since they will not be able to interact and not will stay on body surfaces;
Coverage is thinned due to various adverse conditions, so it needs to be renewed regularly, although it would be 1 time per season. If the owner uses a car in harsh or extreme conditions, then you need to apply the coating more often.
Cleaning glass surfaces
The next, final stage concerns glass cleaning. It is important that during this procedure, special tools are used that are produced without the use of ammonia. This component does not only has a peculiar smell, it also leaves stains on the plastic elements of the car-the dashboard and other parts of the cabin.
- Glasses are cleaned from the inside and outside.
- It is better to use a microfibre cloth for washing, as it wipes off dirt well and absorbs fat.
- While washing, lower the side windows a little to clean the upper glass edge.
- While cleaning the windshield, it is not recommended to put various protective equipment on it. An exception can only be the Anti-Rain tool.
It’s important to remember that in kidslining, particular attention is paid to details, so you need to check all the elements and parts of the car several times to be sure of its cleanliness and beauty. As a result, your vehicle will shine and please the owner’s eye for a long time.
Cleaning and timely car maintenance is an important process that a motorist can’t do without. What is important for this is not only desire, but and the availability of various means and care products. You can familiarize yourself with their huge variety by visiting our website. The catalog contains all the necessary tools to help make the car clean and beautiful. you can buy care products on 130.com.ua.
Related Materials
