Simple tips for keeping your car window clean
It is very important to keep the glass clean, because it is a guarantee of safe trips. 10 simple tips will help you with this.
1. Monitor the condition of the brushes: it is recommended to periodically change the blade. For the winter, we advise you to install special brushes with frost resistance properties.
2. With the onset of cold weather, start using antifreeze to clean the windshield
3. If using a washer with an 80-degree concentrate, be sure to mix it with water. In its pure form, it evaporates very much, we recommend to avoid it.
4. Avoid any liquids that contain methyl alcohol. To do this, buy proven products, ask for quality certificates or carefully study the label.
5. Distinguish between winter windshield washer fluid and freezing, but summer. It is the first option is suitable for frost.
6. If the car is in the garage, clean the brushes and nozzles from dirt and snow. If on the street-do it more often, before each trip.
7. To keep the brushes in good condition for as long as possible, warm the glass slowly and then turn on the wipers .
8. If the glass is very dirty, then you need to moisten it with liquid and only then turn on the brushes: frozen pieces of dirt can damage the system itself and the glass.
9. To clear the glass of the ice layer, use a special tool: scrapers or defrosters. You can buy a scraper with delivery in Ukraine to Kharkov, Kiev, Odessa at 130.com.ua.
10. If you are planning a long time not to use the car, remove the brushes or exclude their contact with the glass. In severe frost, this period can even be a couple of days.
These simple and useful tips will help you keep your glass clean in any weather.
Related Content:
