High engine oil consumption. Causes
A car today is an ordinary means of transportation. They are available and are becoming more technological. But here it is important not only to buy it, but also to properly maintain it. Regularly give a decent amount for the repair and purchase of some components, not everyone has the opportunity. But the older your car, the more money will go to buy special fluids, machinery, and fueling.
One of the most embarrassing moments for a driver is the high consumption of engine oil . It leads to greater expenditure of finances and premature rement. Why is oil consumption so big? There is no huge list of possible reasons, everything is simple-there are only 3 of them.
Ugar
The engine of even the most technologically advanced and advanced cars receives heavy loads, which cause its wear. Therefore, the oil begins to burn out: an excessive amount of liquid accumulates on the walls. Then it combines with gasoline and burns out.
This may be due to wear of the oil rings or reduced compression. And most often-because of poor-quality oil. Therefore, give preference to proven products.
Stream
If the car will stand for a long time without use, sometimes you can see a pool of oil under it. If you are 100% sure that the engine is in good condition, then you just had a leak. What to do? Carefully inspect the engine. Immediately pay attention to the gasket between the engine and the cylinder blocks, because they can deteriorate a lot and no longer hold the oil. If everything is good, then inspect the camshaft, crankshaft.
Using the wrong type of oil
And it really is a big mistake. If you use oil that is not suitable for your engine, in the near future you may encounter serious problems in the operation of mechanisms. Therefore, before buying, be sure to check the quality of the fluid and its parameters with your car. High oil consumption is one of the reasons for the urgent inspection of the engine. If you do not solve this problem, you will have to constantly refill the car and even face expensive repairs. With delivery in Ukraine, motor oil can be bought in Kiev, Kharkov, Odessa on 130.com.ua.
Related Materials
