Petrol or Electric Lawn Mower: Which One Is Better and for Whom?
Choosing between a petrol and an electric lawn mower is not about "which is more powerful", but about picking the right tool for specific conditions. The same plot can be mowed by both types, but comfort, efficiency, and cost will differ. In this article — a comparison of pros and cons of both types, real-life use cases, and tips on how to choose the best model for the job.
Main Differences: What Sets These Types Apart
Petrol lawn mowers use internal combustion engines, don’t rely on electricity, offer high power, and are suited for large plots. Electric ones are lighter, quieter, and require access to a socket or battery. Here’s a comparison table:
| Feature | Petrol Lawn Mower | Electric Lawn Mower |
| Power source | Petrol (usually A-92) | 220V mains or battery |
| Power | High, suitable for tall and thick grass | Medium, ideal for maintained lawns |
| Mowing area | 300–2000 m² and more | Up to 600–800 m² (less for corded types) |
| Noise & vibration | Louder, hearing protection recommended | Quiet, won’t disturb neighbors |
| Weight | Heavier, requires effort | Lighter and easier to operate |
| Maintenance | Regular oil, filter, and spark plug changes | Minimal — cable or battery check |
| Start-up | Manual or recoil starter | Push button or switch |
| Cost | Higher initial and maintenance cost | Budget-friendly for basic use |
Who Should Choose a Petrol Lawn Mower
This model is the go-to choice for large property owners and gardeners working with uneven terrain or overgrown grass. It doesn’t need electricity and handles dense, wet, or tall grass. Often used for semi-professional and municipal jobs.
Use Case: A 1200 m² countryside plot without electricity. Tall grass, trees, shrubs. An electric mower won’t handle it, and a battery will drain quickly. A petrol self-propelled mower is the best option.
When to Choose an Electric Model
Electric lawn mowers are ideal for small lawns near houses or cottages, especially if there’s constant access to power or a battery-powered version is used. No fuel required, quiet operation, and easy handling.
Use Case: A small lawn of 300–400 m² near a private house. The electric mower finishes the job in 15–20 minutes, needs little maintenance, and stores easily.
Battery-Powered Lawn Mowers: A Balanced Option
Those looking for quiet operation and freedom from cords should consider battery-powered lawn mowers. They combine the advantages of electric models with the mobility of petrol ones. Ideal for lawns up to 400–500 m², especially if grass isn’t overgrown.
Pros and Cons of Each Type
Petrol Mower
- Pros: autonomous, powerful, handles tough terrain
- Cons: noisy, heavy, smells, requires maintenance
Electric Mower
- Pros: simple, quiet, lightweight
- Cons: limited by cord or battery, less powerful
Conclusion: Which One Is Right for Your Needs
If your lawn is large, far from power, and overgrown — the obvious choice is a petrol lawn mower. If the lawn is compact, well-kept, and quiet operation matters — go for an electric model. For those who want mobility and eco-friendliness — battery-powered versions are worth considering.
In our catalog, you’ll find lawn mowers for any purpose — from basic home models to semi-professional equipment. Need help choosing? Our consultants will help you find the perfect machine for your plot.
Lawn mower EGO LM1903E-SPBuy40999 ₴ 37923 ₴
