Varta and Bosch batteries are our choice!
Looking for a truly durable and reliable battery? Tired every year to change the next battery of indistinct origin? How much can you suffer with the onset of frost with a failed battery?
If you need a first-class car battery, then you should choose among modern batteries from leading manufacturers. Bosch closely cooperates with almost all global automakers, its series of rechargeable batteries is designed for almost all well-known car brands. Exceptional results of reliability, service life and technical parameters have been achieved thanks to the strictest quality control of products and innovative technologies.
The class and equipment of the car, driving style, features of the weather, the specifics of operating the car-all this must be taken into account in order to know How to choose a car battery .
The main technical parameters that the new battery must meet for normal operation with all electrical equipment in a car must be thought out in advance. These are: dimensions of the case, capacity (A/h), indicators of starting current (A).
Electrical capacity is how much electricity a battery can produce when it is discharged for a long time. Or the ability to produce a specific current in a specific period of time.
The energy reserve, which determines the time of the starter discharge, means how much it will be possible to perform the engine start tests. With a larger capacity-more samples start a car.
Starting power-how much power the battery will give out in 30 seconds at a temperature of minus 18°C. This is the ability to start a cold engine.
It is important that the starting current of the new battery coincides with the values of the previous battery. Electrical capacity also. In some engine modes (idling, for example), during short trips during the day, at night the battery works to help the generator to power the working energy-consuming appliances. If the own electric capacity is insufficient, then the discharge can reach 40-50%. And this is fraught with a drop in battery performance when the engine starts. Repetition of such deep discharges reduces battery life. Therefore, when choosing it is important to choose the right starting current, electrical capacitance, pole position (right plus for reverse polarity, right minus for direct), dimensions (the main thing is length) and fasteners. The potential abilities of the battery can be found in the passport data. It is important to remember that during operation, the state of the battery is directly dependent on the conditions and mode of operation of the machine. You can buy a battery in Kharkov, Kiev, Odessa with delivery in Ukraine at 130.com.ua.
Energy maximum from Bosch S6 AGM
For the stable operation of various systems of comfort and safety of the latest generation of cars, technology is needed that covers marginal energy costs and ensures a reliable start of the motor. The daily implementation of this condition provides the concept of AGM (Absorbent Glass Mat), incorporated in the latest Bosch S6 AGM High Tec batteries. This model is completely unattended, has full tightness and the highest vibration resistance. The non-flowing Bosch S6 AGM High Tec electrolyte gives the battery a very high level of resistance to discharge/charge cycles and a long service life.
There are no special requirements for the position of this battery during installation; it is equally suitable for both premium and medium cars. Bosch S6 satisfies all key standards for the power supply of various boats (ships, etc.). This allows you to apply the model to both auto and water vehicles.
Bosch S5 Silver Plus-always start without problems
The exceptional technical parameters of Bosch S5 Silver Plus batteries, manufacturer to reach the manufacturer through a combination of a large number of innovative developments. A wide range of modifications allows you to install this model on almost any modern car, especially rational for its use in diesel cars.
The so-called "silver technology" increases the durability of the battery by 30%. This model has an increased cold start current and gives a confident start in extreme temperature conditions, and also guarantees the smooth operation of automotive equipment.
Bosch S3 Reliable and Practical
Bosch S3-a classic development in a pragmatic combination with famous German quality. Reliability and durability at a good price. Battery Bosch S3 has such a good balance of reliability and reasonable prices that it can be used in used cars. Sure start of the motor for all the time of operation. This series is focused mainly on those situations when there is a task to provide with electricity a limited number of auxiliary equipment and stable start-up in any climatic conditions.
Solution for all cases-Bosch S4 Silver
It is worth noting that the Bosch S4 Silver line currently covers the market by 97%, so you can pick up the required battery for almost any car. In addition, this line includes Asian-size batteries (JIS standard). Practical advantages are obvious from the first trip, this is the uninterrupted operation of the starter due to the increase in the strength of the cold start current in any climatic conditions. Reliability, stability and simplicity traditionally distinguishes a number of Bosch S4 Silver rechargeable batteries. And also it is characterized by a successful combination of price with technical indicators and quality.
Bosch T5 HDE Cargo Battery
“Heavy Duty Extra” is an original design that allows you to achieve impressive cycle resistance and special durability with the highest demands. This is the best option for heavy vehicles. The silver-calcium alloy and the labyrinth structure of the Bosch T5 HDE cover are responsible for high efficiency. Due to the stability of the cover against tilting, the labyrinth does not allow acid to leak out, and it returns to the correct compartment in the battery. Built-in frit provides reliable protection against ignition and sparking occurring around the battery. The difficulties of a cold start and the need for periodic maintenance are problems of the past.
Multipurpose Varta Dynamic Trio
The famous Dynamic Trio series covers a large number of applications, since each of its batteries is designed for its specific direction. All of them are united by progressive development-stamped lattice Power Frame, which as a result gives the highest indicators of strength and corrosion resistance in all situations, even in the most extreme. At the heart of the manufacture of the Power Frame grid is rolled metal strip, which is subsequently stamped into the grid. Thus, high quality is achieved and battery power is increased. Rental allows you to stretch the metal grain, and with other methods (perforation, casting, stretching), the structure of metal grains becomes vulnerable to corrosion.
Blue Dynamic
Honored option for all cases. Top sales among replacement batteries is the right choice for different classes of vehicles. High-quality battery Varta Blue Dynamic has excellent performance starting power, large charging capacity, power cold start, meets the requirements of the OE.
Silver Dynamic
When battery requirements are high, the Varta Silver Dynamic battery will manifest itself at the highest level. This is true for vehicles with a wide range of electrical equipment and increased operational parameters. Cold scroll current reaches a unique level of 122%. Varta Silver Dynamic is a premium-grade lead-acid battery, reliable and compliant and exceeding EO standards. Serious cold start power allows you to be confident in this battery anyway.
Black Dynamic
Option for vehicles with less demanding requirements for energy supply. Reasonable price plus almost proven quality-this is Varta Black Dynamic. Full reliability, uninterrupted performance, excellent starting power, 100% cold scroll current for cars with basic equipment.
Miserly pays twice-common truth for many occasions, including automotive. Trust the best, choose what motorists around the world trust, be confident in your car with the most modern and reliable Bosch and Varta batteries. Buy your battery today in the online store 130!
Materials on the topic
Car batteries: Best Sellers
