Cordless Trimmers: How Convenient Are They in Real Use?
The popularity of cordless trimmers is growing every season. More and more users are ditching cords and fuel in favor of compact, lightweight, and eco-friendly options. But how convenient are these tools in real-life situations? How long does the battery last, what tasks can it handle, and are there any downsides to consider before buying? This article offers an honest breakdown of the advantages and limitations of battery-powered tools.
Why cordless trimmers are convenient
The main advantage of a cordless model is complete freedom of movement. No cable dragging behind, no fumes, oil, or noise like a gas brushcutter. For homeowners and gardeners, it’s the perfect middle ground between a corded trimmer and a bulky gas machine.
- Works without a power outlet — mow anywhere you want;
- Quick start — just push a button and go;
- Lightweight and compact — often weighs under 3 kg;
- No need for fuel or regular maintenance;
- Low noise and minimal vibration.
Example: a 500 m² lawn around a house. You need to trim edges near the fence and flowerbeds. A corded trimmer can’t reach — the extension cable isn’t long enough. A gas one is too noisy and heavy. A cordless model gets the job done in 15–20 minutes with no smell or wires.
How long does the battery last?
One of the main concerns — how long a cordless trimmer can run on a single charge. On average, it's 20 to 45 minutes, depending on battery capacity and load.
- Typical battery: 2.0–4.0 Ah;
- Full charge time: 1.5–2.5 hours (depends on charger);
- Idle use consumes less battery, cutting thick grass drains it faster;
- Some models support dual batteries for extended runtime.
Tip: For lawns larger than 400–500 m², consider a second battery or a model with fast charging. It will save time during the active mowing season.
Downsides of cordless trimmers
Despite all their benefits, cordless tools still fall short of gas-powered models in terms of power. This is critical if you're tackling overgrown or neglected lawns.
- Not ideal for tall, thick weeds — may overheat or discharge quickly;
- Limited runtime (especially with budget batteries);
- Batteries degrade over time (like smartphone batteries);
- Higher price tag compared to corded trimmers.
Example: If your lawn is overgrown and you mow once a month — better go for a gas brushcutter. A cordless trimmer won’t be powerful enough.
Who needs a cordless trimmer?
The best use case is routine maintenance of a small- to medium-sized lawn, edge trimming, or soft grass cutting. Especially relevant for areas with no convenient access to power outlets or where noise is a concern (like garden plots, patios, or near gazebos).
Conclusion: Is it worth it?
If you want a lightweight, quiet, and mobile tool for simple tasks — a cordless trimmer is an excellent choice. It won’t replace a brushcutter, but it’s much more comfortable and cleaner for day-to-day use. Just make sure to pick a model with a suitable battery and don’t expect it to handle heavy weeds.
In the 130.com.ua catalog, you’ll find cordless trimmers from trusted brands. Models with one or two batteries, different cutting widths, and adjustable shafts. Our experts can help you find the best option for your needs.
Lawn mower EGO LM1903E-SPBuy40999 ₴ 37923 ₴
