Actual: how and for how much you can install heating mirrors, seats and wipers!
Even in the fall, when the winter season is just around the corner, we have little thought about what difficulties we will face in the near future. Residents of Eastern Ukraine feel before everyone else what it is like to literally tear off their wipers and other delights of this pore. Of course, some modern models of cars are equipped with built-in heating, but this applies only to the luxury class.
It seems to be such a small thing, but how can it save drivers who are in a hurry somewhere, and in general will be a practical solution for frost. Do not worry if your car does not provide such a function. You can easily install it yourself. It is possible to buy heating of mirrors, seats, janitors in Odessa, Kiev, Kharkov with delivery across Ukraine.
Mirror Heaters: Views and Features
Consider the basic model of heating mirrors:
- on a wire basis;
- based on printed conductors;
- film construction.
If you focus on reliability and functionality, the film look is the most suitable. This is a thin conductive current-layer, which is installed on double-sided tape. It is mounted on the reflector glass: it turns out that it together with the heater is one design.
What we get in the end? The mirror is uniformly heated over the entire area. Average temperature range: 50-70 degrees. You can make the inclusion using a separate button or to the rear window heating button-as you like.
Install the driver will be able to every driver. To do this, use the following algorithm:
1. We install new heated mirrors. Please note: you must first push the wires of the mirrors inside the door.
2. Remove the trim from the door.
3. We fix the wires from the mirrors in the door.
4. We conduct and connect the front panel wiring to the rear window heating button.
5. If necessary, instead of the rear window heating button, install the three-button key.
6. Check if heated mirrors .
7. Back set trim in the door.
That's it: just buy a heated mirror and just 7 simple steps to enjoy the new function in your car.
Heated Wiper
With heated wipers , things are much simpler. This is a flexible heating element that is mounted in the lower position of the brushes. For example, such "regular places" are provided for Volkswagen from 2005.
Of course, you can install heating yourself, even if it is not provided by the design of your car. But note that due to improper installation or selection of an unsuitable heater, the glass may overheat and burst.
As you can see, saving does not lead to anything good. If there is no regular place to install, it is better to invest in the services of specialists.
Heated seats
If, of course, properly set up heated seats, they will provide you a comfortable stay in a cold car. Please note that even here saving is not recommended at all, because such structures quickly break down and can even ruin the upholstery.
Heated seats is a safe device that can be embedded inside the seat or as a cape. For example, the model cape HEYNER WarmComfort Pro 506600.
Features:
- Uniform warming up: there is no such thing as “already burning” on the back, and the seat pad is still barely warm.
- Simplicity: without the involvement of specialists, you can install and remove if necessary.
- Wear-resistant, reliable: full protection against possible overheating, circuit.
- Adjust the heat: 3 modes are available.
Just a few simple steps and possible problems in the winter are minimized.
Materials on the topic
Seat warmers: Best Sellers
