How to ensure good visibility on a winter road: useful tips for motorists
In harsh winter conditions, maintaining excellent road visibility becomes essential for safe driving. Low temperatures, snowfall and ice create difficulties and require maximum concentration and attention from the driver. It is very important that the road is well lit and the driver has full visibility. In this case, he will be able to make prompt and rational decisions in case of emergency situations on the road. Let's look at the main points that you should pay attention to when preparing your car for winter.
Lighting system and headlight adjustment
To ensure good visibility on the road in any weather, especially in snow and rain, you need to monitor the condition and adjustment of the headlights. Periodic polishing of headlights using special polishes will help get rid of scuffs and add shine, and also increase the brightness of the light beam.
Do not forget that you need to correctly adjust the position of the headlights so that they are on the right track, and avoid minor damage that could disrupt this setting.
Don't forget to use headlight range control, especially if it's manual. Changes in the vehicle's weight, for example due to an overloaded trunk, can affect the direction of the light beam as the front of the car may ride up. And the road will not get enough light.
If the standard headlights are not enough, consider installing additional ones. However, before doing so, think about the desired result - improving visibility in different weather conditions or providing additional light for specific situations. For example, fog lights can be useful in conditions of heavy fog, snow or rain. Consider using them, especially if your vehicle has space for them but doesn't have them installed.
If more light is needed, for example for an SUV or a utility vehicle that often has to drive in difficult conditions, such as in the forest, additional headlights can be an excellent solution. With their help, you can achieve the necessary lighting to complete your tasks, and the beam can be directed in any direction.
Replacing lamps
To improve the quality of your car light, you can also consider replacing your standard car bulbs. Unlike installing additional headlights, changing a lamp seems like a fairly simple step: remove the old one, install a new one, and the result is an increase in brightness of up to 200%. But it’s important to be careful here.
Car headlights are initially designed for a specific type and power of lamps. Using a bulb with excess power can cause the lens to overheat, and the increased power flow can damage the wiring and fuses in the vehicle's electrical circuit, ultimately leading to malfunctions.
For conventional halogen lamps, it is recommended to choose analogs with increased power by no more than 20-30%, this will avoid possible problems.
If you are planning to install LED lamps that are bright and efficient, you should keep in mind that budget options may have a limited service life and problems with focusing the light. High-quality LED lamps are usually equipped with a control system and additional cooling, but their cost is higher.
It is also important to note that LED lamps can create a light beam that is too intense, and this requires the presence of additional lenses inside the headlight that could ensure correct focusing. Otherwise, you may cause discomfort to oncoming drivers on the road.
If you are considering installing xenon in conventional headlights, you must remember that this requires an integrated approach. You will need to install a special control unit, a fryer, and sometimes additional lenses may be required.
Wipers
Selecting quality windshield wipers plays a key role in ensuring excellent visibility on the road, as they are designed to clean the windshield. Regular replacement of these elements is very important, especially if signs of wear appear, such as squeaking or areas on the glass that are not completely cleaned. If this is not done on time, then in cold weather the wipers can quickly fail, as the load on them increases significantly.
The types of wipers are as follows:
- Frame: They have a metal frame made of several elements, which makes them simpler and more affordable in terms of cost. However, about may be damaged by snow and ice buildup, and may produce more noise when driving at high speeds.
- Frameless: Made in the form of one continuous strip with a powerful pressure plate inside. They are more expensive, they can be cleared of ice quite easily, and they create less noise due to their profiled surface and better pressure against the glass.
There are also intermediate options, such as frame wipers with a spoiler and hybrid ones, but they are quite rare in stores.
Choosing the right washer
In addition to choosing wipers, it is also important to pay attention to the washer. It is recommended to use liquid from well-known manufacturers, who guarantee the absence of harmful alcohols in the base and normal flavorings.
Cheap washes often contain dangerous alcohol and harsh fragrances that are used to mask the intense alcohol smell. The optimal choice will ensure efficiency and safety for use in a variety of weather conditions, while maintaining the cleanliness of your car glass.
Auto chemical goods
In winter, special automotive fluids, such as anti-fog and anti-rain, become important assistants for the driver.
- Anti-fog is a special composition applied to the inside of the windshield, it is designed to prevent condensation and fogging. This is especially important on damp winter days and when there are a large number of passengers in the cabin.
- Anti-rain is a product that is applied to the outer surface of the glass and acts as a polish, smoothing the surface. This speeds up the drainage of water and reduces the likelihood of snow and ice freezing.
Special glasses for the driver
Another means of improving visibility on the road is special glasses for drivers with yellow-brown lenses that increase contrast. This is especially useful on snowy roads, where the entire landscape around you is a solid white and gray canvas.
Some models of such glasses are treated with an additional protective layer on top, which allows you to protect your eyes from the blinding headlights of oncoming traffic.
As you can see, there are many options for improving visibility on a winter road. And it is important not to ignore this point. In the future, your health and even your life may depend on how you prepare for driving in difficult conditions!
Related materials
