Dazzling xenon make-up cars
Not so long ago you could see xenon in the lighting system of only elite cars. But the years of the xenon revolution in automotive lighting made this technology available to a wide range. "Xenon-eyed" cars are more common today. What prompts motorists to buy xenon to illuminate their cars and what is its attractiveness?
All the answers are in the technical essence of the device. Xenon lamps work according to the following principle. In a glass bulb of a lamp through a specially selected mixture of inert gases, where the main is xenon (xenon), an electrical discharge from a special high-voltage xenon ignition unit passes. The result is a glow of the gas mixture. This technology reduces power consumption (almost 2 times) and increases lamp life, and in terms of durability, xenon headlights significantly (on average 5 (!) Times) outperform other types. The main value, which gives xenon (motorists reviews-confirmation of this), is the temperature of the glow, as close as possible to the temperature of natural sunlight (about 4,300 Kelvin). Installing xenon significantly reduces fatigue of the driver's eyes and contributes to better illumination of the path, without "blinding" the drivers of oncoming vehicles. Brighter and more intense illumination of the road, a significant improvement in visibility and a wider and clearer field of view-all this helps motorists to achieve high-quality xenon light, the price of which is not limited to the cost.
This is a significant contribution to the safety and comfort of your trips, especially at night and during bad weather.
Especially popular was xenon, which every car owner can now buy, with the start of the production of lamps with the traditional N-type base provided in the headlamps of most cars. And now xenon for cars is a regular spare part, if not installed by the manufacturer, then it is an option for absolutely any car. Install xenon on Lanos, VAZ, motorcycle or scooter today is not a problem. And all existing types of bases in the xenon systems, presented on the modern market of auto lighting, not only attract more consumers, but also eliminate the need to replace the entire set of headlights when installing xenon. It should be noted that after installing xenon lamps instead of halogen lamps, it is necessary to check and calibrate the headlights at specialized service stations. buy xenon lamps in Kiev, Kharkov, Odessa at 130.com.ua with delivery in Ukraine.
Given the likelihood of introducing a long-awaited new traffic regulations requirement in Ukraine and the prospect of Ukrainian drivers driving around the clock with a car light on 7 months a year, it’s worth once again to think about your car lighting. To increase its efficiency, xenon headlights are just capable due to the already mentioned durability, economical energy consumption and the “right” glow. And if you compare the cost of high-quality halogen lamps and relatively affordable xenon, you can understand that installing xenon in a car helps save money to the car owner and at the same time increases the safety of driving a car! Contact us to give your car a modern xenon “look” and increase the safety and comfort of your trips.
Materials on the topic
