Selecting a GPS tracker starts with this information!
Not so long ago, a device such as a GPS tracker appeared, however, today, the device has definitely won its special place among the ways to get information. But this is not strange, because the device differs in a variety of fields of application, and even more potential users still do not suspect what possibilities this device opens up. GPS tracker, or as the GPS beacon or GPS tag is also called, determines the location of the object and transmits the information with the coordinates to a special site, SMS notification to the phone or to the application for the smartphone. You can easily and quickly find out where a person is, a vehicle or any other object on which the GPS beacon is installed. Moreover, this modern car accessory can perform not only the function of monitoring the location of an object, but also a security one, since certain models give commands to the car, such as, for example, blocking the engine. These functions clearly convince us that a GPS tag solves a wide range of tasks, but let's get to the details to know which tracker is right for you.
Types of GPS trackers
- Personal GPS tracker-determines the location of a person or an object, respectively, works autonomously using a battery or battery.
- Car GPS tracker is designed to be installed in the car, and can work both from the on-board car network and using autonomous power.
GPS beacon consists of the following basic elements:
- GLONASS/GPS receiver-to determine the coordinates;
- Satellite dish-external and built-in;
- Information processing chip;
- Transmitter for GSM/GPRS network;
- Battery;
- Built-in memory.
The device operates in such a way that it locates by satellite signals, calculates and transmits geographical coordinates, and the recognition accuracy is up to ten meters. A SIM card is inserted into the device through which information is exchanged. When choosing a GPS tracker, you should give preference to the device with the maximum number of SIM-cards. Different mobile operators have different coverage areas in remote areas, thus, you will increase the chance of uninterrupted network operation.
When choosing a GPS tracker, pay due attention to the power source. If you buy a GPS beacon for a child, or you want to install a hidden GPS tag, then a model with power from a battery or batteries will suit you. Basically, the power consumption of the device and the frequency of switching affect the running time. When you choose a GPS beacon for installation on a car, onboard-powered models will be more appropriate. Since this device is popular among different types of vehicles, there are options with an operating voltage from 12V to 36V. choice will simplify the model of the tracker with a mixed power system.
In the current market, GPS beacons are presented with different prices and technical capabilities, ranging from simple and moving to more complex, which can provide extensive information on the object. To any GPS tracker there is an instruction, where you can find out what additional features the device is endowed with. We give an example of the most popular.
Additional GPS tracker features
- Built-in microphone-allows you to communicate with the device imperceptibly and listen to what is happening near the device.
- Accelerometer-captures the movement of the car and signals it to the owner.
- The SOS function is the transfer of object coordinates with a frequency of 5-10 minutes. Especially true during the hijacking of a car, but because of the frequency of switching on, it sits the battery for several hours.
- Geofence-a notification comes when the object crosses an established area.
- Record waypoints-in the absence of GSM/GPRS communication, the tracker captures and remembers the coordinates. When you resume communication with the GSM/GPRS channel, it sends all recorded waypoints.
- Additional control-the ability to send SMS commands to the tracker that locks the doors, the engine or turns on the lights.
- Additional sensors-connect various sensors, for example, fuel, temperature, door opening/closing, engine speed, engine hours and others.
It is important to remember:
In its work, the GPS beacon constantly interacts with satellites, GSM operators and a server via the Internet to transmit information to the user. In this regard, there may be interruptions in the operation of the device in case of problems with any of the parties. For example, if the tracker is installed in a covered building with a metal roof, in a subway or underground parking, the satellite signals may not reach. In this case, the last defined coordinates of the object will be displayed, but if additional signal transmitters for mobile communication are installed there, the device will work. Bad weather conditions interfere with the transmission and reception of signals, and the lack of an Internet connection will not allow you to send a request to receive data and location.
See GPS tracker video reviews
Choose the best option for you and buy a GPS tracker in Kharkov, Kiev, Odessa with delivery in Ukraine you can site 130.com.ua.
Related materials
GPS trackers: Best Sellers
