What to look at when choosing a car vacuum cleaner?
Of course, the car has long been moved to the stage of necessary things, especially for large families. But it is necessary to take into account the appearance of certain obligations, among which is maintaining cleanliness. And if you have children or animals, it is much more difficult to maintain order. For each, this problem is solved in a different way: it is convenient for someone to call in a car wash every evening, someone generally cleans up once a month. The universal and practical solution is to buy a car vacuum cleaner. Let us consider its construction in more detail.
Dust Collector
Car vacuum cleaners are distinguished by filter design-container and cyclone. The first type is more durable: air with garbage is blown through the compressor through a special filter, where all the garbage remains. Benefits:
- ease of management;
- affordable price;
- compactness.
But there are also disadvantages, for example, a small amount of the filter itself, noisy work.
Models with a cyclone filter have a constant suction power. There are no bags that need to be periodically cleaned and shaken out. The container is transparent, so you can easily find some lost small things.
Power
If we compare automotive models and conventional ones, then the first ones have a power consumption parameter of 10, or even 20, times less. Therefore, they are not even compared with high-grade constructions of 220 V.
Depending on energy consumption, vacuum cleaners are:
- low-power (up to 80 W);
- powerful (over 80 watts).
Please note that not every cigarette lighter can withstand the connection of a powerful device. Therefore, consider the capabilities of your car.
The suction power parameter depends on many factors, for example, engine power, hose design, and nozzle shape. Of course, this indicator is significantly less than that of full-fledged vacuum cleaners.
Do not forget that automotive technology can not compete with household models. These devices differ in their tasks-the first type is designed for express cleaning.
Some models are equipped with a twin-engine system, but they are effective only on fabric surfaces. There are no standards for the suction power indicator: some manufacturers measure it with a filter, and others without it. Therefore, keep in mind that this figure may differ from what you see in practice.
Power
Standardly, vacuum cleaners connect to the vehicle’s electrical system. The length of the wire is enough to clean the cabin, and if it is a hatchback or station wagon, you can still get to the trunk.
There are also standalone and versatile models that can work from the on-board network and from the built-in battery. Please note that the battery charge is also not durable, and therefore the operating time is limited.
Additional tips
In your salon there are different surfaces and fabrics that you need to clean with different nozzles. Nozzles can be active (with an integrated additional motor) and passive (plastic components). The most popular second option.
The complete set of each model is individual. More advanced include: standard brush, small slotted brush, turbo brush, slotted nozzle, wide nose brush, dust brush, slotted brush, etc. You can buy car vacuum cleaner in Odessa, Kiev, Kharkov with delivery in Ukraine in the online store 130.com.ua.
What you need:
- flexible-for cleaning in corners, narrow crevices, hard-to-reach places;
- flat-for the trunk;
- electric brush-for upholstery;
- with a wide spout-for cleaning ducts;
- with a hard nap-to remove dried dirt;
- soft nap-for dust;
- serrated-for lint.
There are also devices with wet cleaning, which is especially needed when there is bad weather outside the window.
Materials on the topic
Car vacuum cleaners: Best Sellers
