How to choose a refrigerator for cars?
Before you choose a car cooler, you need to decide on its appearance, whether it will be a cooler bag or a refrigerator box. Next, you need to pay attention to the type of refrigerator. Auto-refrigerators are compressor and thermoelectric.
Also, important criteria are the internal volume of the refrigerator for cars, the type of power and the presence of the heating function. Looking for a car cooler? Buy in Kiev, Odessa, Kharkov, you can at 130.com.ua. Delivery in Ukraine.
A car refrigerator will be a very useful attribute for trips to the sea or the countryside, especially during the warmer months. It will keep drinks chilled, and this is sometimes lacking in hot weather.
Auto-Fridge Type
To select a car cooler based on its type, click on the corresponding image.
More information about types
Compressor
The design of the compressor has a compressor and refrigerant. The principle of its operation is the same as that of domestic: cooling occurs due to boiling of the liquid refrigerant in the evaporator.
Pros:
- The temperature inside does not depend on the ambient temperature;
- cooling to minus temperatures is possible.
Cons:
- large size and heavy weight;
- vibration sensitivity
- high cost (prices are an order of magnitude higher than that of thermoelectric).
Thermoelectric
Thermoelectric coolers have no moving parts and no refrigerant. Therefore, are considered environmentally friendly. In them, the cooling is based on the Peltier effect: through the semiconductor wafers, which are located inside and outside the refrigerator, electricity passes. In cooling mode, the plates that are inside the chamber are cooled and the outer ones are heated.
Pros:
- able to work on heating;
- insensitive to vibrations;
- smaller and lighter.
Cons:
- The temperature inside the refrigerator depends on the ambient temperature;
- cooling maximum to + 5° С. On average, cooled below -15° C of ambient temperature.
Type of auto-refrigerator
To select a car cooler based on its appearance, click on the corresponding image.
More information about species
Advantages of auto-coolers-bags:
- Low weight
- Easy to carry
Advantages of box coolers:
- More power and better cooling
- Some models can operate on 220V mains
- Some models have a heating function
Power Type
To select a car cooler based on its type of power, click on the appropriate image.
More information about power types
Auto-refrigerators powered by an onboard 12V network are connected to the vehicle’s cigarette lighter, so they can only be used in close proximity to the car.
Auto-refrigerators that operate on 12 and 220V mains can be connected to the vehicle’s cigarette lighter as well as to 220V mains, for example, at home or in a garage.
heating function
To select a car cooler based on the heating function, click on the corresponding image.
More information about the heating function
With the refrigeration function With the heating function, it is possible to keep the temperature of hot foods for several hours. This feature is not designed to heat cold foods.
Volume
To select a car cooler based on its internal volume, click on the appropriate image.
| 7 l | 8 l | 10 l | 14 l | 15 l | 16 l | 17 l | 18 l | 19 l |
| 20 l | 21 l | 22 l | 23 l | 24 l | 25 l | 26 l | 27 l | 28 l |
| 29 l | 30 l | 31 l | 32 l | 33 l | 35 l | 36 l | 38 l | 39 l |
| 40 l | 41 l | 42 l | 44 l | 45 l | 46 l | 53 l | 60 l | 80 l |
| 85 l | 88 l | 106 l |
The lineup
Related materials
Car Refrigerators: Best Sellers
