Everything you wanted to know about snow chains
Winter road conditions are a major challenge for drivers, and snow chains can be a reliable ally in bad weather, as they increase safety and improve handling. They can help to make driving on snowy and icy roads easier. They perform the important function of transmitting torque to the road surface, preventing skidding and ensuring driving stability.
Take care of your safety on the winter road in advance. Our online store 130.com.ua offers you to buy snow chains with delivery in Ukraine.
What are snow chains?
Snow chains, often simply called "chains," are made of a special steel mesh. As a rule, alloyed manganese or titanium steel is used for their production, which ensures durability and efficiency of operation in a wide temperature range.
Snow chains are an essential element of winter road safety, providing drivers with confidence and peace of mind in the most adverse climatic conditions.
The main purpose of snow chains is to ensure driver safety when driving in areas with unfavorable road conditions, such as ice and deep snow. They prevent skidding by guiding the wheels of the vehicle along the road and improving traction, thereby ensuring the stability of the vehicle on slippery surfaces. In addition, the chains are actively involved in the braking process, providing additional friction and shortening the stopping distance.
Winter chains are not only used on passenger cars. They can also be fitted to trucks, buses, motorcycles and even certain types of agricultural and construction equipment. This versatility makes them the most effective means of ensuring winter road safety, suitable for various types of vehicles.
Features of installing snow chains
The correct installation of snow chains is key to ensuring maximum efficiency and safety in winter conditions. It is important to take into account the specifics of vehicles with different types of drive systems.
- Front-wheel drive: With snow chains fitted to both front wheels, this option ensures that the traction is distributed evenly and provides stability when driving forward.
- Rear-wheel drive: If you have a vehicle with rear-wheel drive, snow chains must be fitted to both rear wheels. This is especially important to prevent skidding and to ensure optimal traction.
- All-wheel drive: For vehicles with all-wheel drive, we recommend fitting snow chains to all four wheels. This ensures an even distribution of traction and maximum grip in any direction of travel.
Never install snow chains on only one tire. Doing so may result in uneven force distribution and affect the vehicle's handling. If you are in doubt about where to install the chains, refer to your vehicle's owner's manual or consult the manufacturer.
Also remember to always read the manufacturer's instructions before driving with snow chains and make sure everything is properly and safely installed. This is a very important step to ensure your safety and the safety of your vehicle while driving in harsh winter conditions.
There are many different reasons to use snow chains on the road:
- They are recommended if you want to increase the grip of the wheels on the road surface, especially on icy or snowy roads to improve safety.
- They make it easier and faster to overcome the most difficult sections of the road (for example, steep climbs).
- Chains also help to save time and money by enabling the driver to continue driving even in heavy snow or ice, so there are no delays or problems with the transportation of important goods.
Snow chains are only recommended for use when road conditions warrant. They are designed for driving on icy and snowy roads, but what if there is asphalt and a more passable section of the road that is not covered with ice or snow? In such a situation, the chains must be removed and reinstalled when the road is covered with ice or snow again.
Rules for the use of snow chains
There are a few simple rules that will not only increase safety while driving on icy roads, but also contribute to their longer service life.
- Avoid sudden braking: Avoid braking hard whenever possible when driving with snow chains installed. This helps maintain consistent chain tension, prevents wear and tear, and provides better handling on slippery surfaces. Smooth and gradual braking contributes to a safer ride.
- Be careful with the accelerator pedal: Do not press the accelerator pedal too hard. Balanced and moderate accelerator pressure prevents excessive chain tension and improves traction. This also helps to ensure that the chains are treated gently, extending their service life.
- Check the tension of the chains regularly: Check the tension of the snow chains every few kilometers while driving. Regular checks allow you to detect potential tension problems and correct them in a timely manner. Maintain the correct tension for optimal chain performance.
- Tighten loose chains in a timely manner: If the chains become loose while driving, stop in a safe place and retighten them. This important rule ensures continuous traction and prevents potential hazards. Do not overlook chain tension as it plays a key role in safe driving on slippery surfaces.
Materials on the topic:
Snow Chains: Best Sellers
