Vibration Isolation Tips
More and more requirements motorists impose on the comfort of movement. In particular, the silence, good sound of music and the ability to talk not in a raised voice with the interlocutor. One way to reduce noise is noise insulation, of which vibration insulation is an integral part.
So, to get rid of the noise, you need insulation, from vibrations-vibration isolation, from squeaking-antiskripny material. In the complex, these materials are able to make a perfectly quiet car, in which no strong rain or other signs of traffic can be heard.
Typically, such materials have the form of a porous and fibrous coating, which on one side are covered with a protective film. Such designs are completely safe: do not emit harmful substances, toxic odors when exposed to high temperatures. Therefore, they can even be used in cars where children are often transported or for allergic drivers.
Important Features
Vibration insulation materials for cars can be equipped with sound-absorbing properties: most coatings operate in the frequency range equal to 600-4000 Hz. This means that they can absorb up to 90% of the noise coming into the car from the street.
Before to buy vibration isolation , consider the following characteristics:
- KZP: sound absorption coefficient. Of course, the higher it is, the more effective it will be to cope with its tasks.
- Thickness. Give preference to thick sheets for vibration isolation of the floor or roof, otherwise take into account the nuances of the trim specifically for each element of the car.
- The presence of waterproof properties. since such structures have a long service life and prevent corrosion of the car body.
In order for the insulation to have the maximum effect, you need to take a comprehensive approach to this process:
- Doors. Due to the fact that the material on such elements in a flat, through the door gets the most noise. In addition, this procedure helps to improve the sound acoustics. Here pay attention to the weight of the material, which should not be too high to avoid deflections in the doorways.
- Ceiling: we get rid of noise that appears due to movement at high speeds or reduce the audibility of rain, hail, snow.
- The floor is the source of the most audible noise: the hum from a rough road, a motor, a suspension.
- Arches-transmit strong vibrations, so you shouldn’t forget about them too.
- The hood is the source of engine vibration.
In addition to sound insulation and vibration isolation, do not forget about antiskripnyh materials that eliminate the possible noise from the friction of small elements. If you do not understand at all in this process, then it is recommended to ask for help in installing vibration isolation in a car to a professional. With delivery in Ukraine, vibration isolation can be bought in Kiev, Kharkov, Odessa at 130.com.ua.
Materials on the topic
Noise insulation: Best Sellers
